Drying riding kit a...
[Closed] Drying riding kit after wet ride
Got home from an exceptionally wet night ride on Monday night - caked head to toe in mud. Striped off, hosed stuff down then hung up in garage to dry off. By last night the stuff was still wringing wet. A pair of waterproof trousers I was using the week prior were also still wet.
Garage is a-typical garage - couple of air bricks to front, couple of air bricks to rear and no heating.
Anyone had clever methods of drying wet kit?
Posted : 23/11/2017 11:31 am
Washing machine straight away. Tumble dryer for the stuff that can be, drying rack clothes horse thing next to the radiator over night. Are you over thinking it?
Posted : 23/11/2017 11:33 am
Wash, fast spin, hang by radiator.
Surely it can't be more complex than that? It's what I did last night!
Posted : 23/11/2017 11:36 am
PRetty much anything can be tumble dried, really. I find. But maybe I like to risk things. Nothing's been ruined though.
Posted : 23/11/2017 11:37 am
the garage is cold , damp and has no air flow....
yep thats ideal drying conditions - see also calm winters days.....
mine hang on the line for the worst of the water to drip out then move onto a clothes horse near the fire.
boots go near the fire asap if i want any chance to wear them again the next day.
dont have a tumble drier and dont believe in washing waterproof fabrics more than is necessary ie if i washed mine every time it got wet and muddy it wouldnt be waterproof very long 😀
Basically as @jekkyl and @submarined have said. If stuff is really mucky then a soak in a bucket to get most of it off before shoving in washing machine. We don't put shorts/bibs with pad inserts in the drier but hang them up to dry next to the radiators.
Posted : 23/11/2017 11:39 am
What, no one else fitted a radiator in their garage ........... 😉
My garage is usually around 60-65 degrees when the heating's on...
Posted : 23/11/2017 11:43 am
I wont use a dryer on my mtb kit but find that sticking it in the wash the next day means it dryes quicker.
naw- no insulation in the walls or properly air tight door means id be spending money to heat the atmosphere seems like wasteful madness - a bit like remapping your vw t5 they said.
Posted : 23/11/2017 11:45 am
I always leave my shoes and helmet in the house to dry in winter, even if it’s not a rainy day but the sweat still needs to dry.
Nothing worse than a mouldy helmet strap if you leave a slightly damp helmet in the garage.
Posted : 23/11/2017 11:47 am
I try to avoid washing waterproof stuff too much too.
You’re not going to dry much in a garage.
My 5:10 get stuffed with nappies (got loads the youngest grew out of but they’re pennies to buy if you get cheapo supermarket ones).
Jacket get hung in the [s]lean-to[/s] Orangery it’s not heated but it’s only a single pane of glass from the house so is warmish. Rest goes in the washer and dryer / rads.
God I hate winter.
Posted : 23/11/2017 11:48 am
no need to tumble dry bike kit it's all quick drying.
Same as Submarined says above. Hose off then quick 30deg wash cycle with fast spin (incl. shoes). stuff comes out practically dry. I just hang my bike kit up on coathangers on the curtain rail in a south facing bedroom window and the sun dries it within an hour. (or above a radiator if for some strange reason it isn't sunny)
wet shoes dry in the boiler cupboard.
Sounds like you didn't even wring yours out. Are you a student who's just left home or something? 😛
Posted : 23/11/2017 11:49 am
Our HW system is very old fashioned - we've a HW cylinder with airing cupboard. The cylinder is insulated but it's still nicely warm in there so sticking helmets and shoes* in with it dries things out gently.
*Five Ten shoes excepted 🙄
Posted : 23/11/2017 11:53 am
Desk fan. I used to use one to dry my commuting kit at work.
Posted : 23/11/2017 12:05 pm
 cnud
I fitted a 45w towel rail in my garage on a timer, cheap enough to run and does a good job of drying kit.
[url= https://www.alertelectrical.com/dimplex-s50-dry-element-towel-rail.html?qs=dimplex%20towel%20ra ]Clicky[/url]
Posted : 23/11/2017 12:29 pm
Build a drying room in your house?
Personally I wash stuff and then put it out to dry on clothes horse thing. (where ever Mrs FD doesn't get too peed off)
I would fast spin sports clothing or tumble dry it mind.
Posted : 23/11/2017 12:31 pm
I recently picked up a heated airer from aldi that I put up in the garage for super wet gear. It's not massively hot but it dries stuff enough overnight/slowly which means I can then hang it next to a radiator to finish it off. The garage floor then dries by itself from the huge puddles/drips and I can just sweep any dried mud out the garage door. That way it saves carpet or the living room getting a flood or major mud.
Posted : 23/11/2017 12:33 pm
If it needs to dry quick then inside the house. If it can be slow then my garage is fine, it's very leaky though (through gaps in front and rear doors). I often hang a tarp or tent inside to drip dry, or my bike or motorbike go in there wet. They dry out just fine
Posted : 23/11/2017 12:37 pm
Garage is a-typical garage - couple of air bricks to front, couple of air bricks to rear and [b]no heating[/b].
mmm some form of heating? Just a cheap wee blown air heater left on for an hour or so will make a difference. Although I take wet kit in the house to dry. I have a shoe dryer in the garage but everything else bar my helmet goes in the house.
Posted : 23/11/2017 12:38 pm
Same but get most of mud off beforehand with a hose or in the bath/shower to prolong washing machine life (I hope). Don't machine wash my jacket each time though, this is either dried in the shed or indoors if clean enough
Posted : 23/11/2017 12:42 pm
Hang it in front of the aga.
Works a treat.
Posted : 23/11/2017 12:44 pm
I've always fancied a drying cabinet. We stayed in a hotel in Finland that had them in every room for ski kit.
They circulate warm air and are much more gentle than a tumble dryer. A quick Google throws up this spendy version, I suspect there are cheaper alternatives around
[url= https://www.iconappliances.co.uk/laundry/drying-cabinets/peko-ets1700e-drying-cabinet.html ]Drying Cabinet[/url]
Posted : 23/11/2017 12:47 pm
lol @ build a drying room.
Posted : 23/11/2017 12:52 pm
Wash n dry at work and use drying room for shoes and bags etc.
The one thing from work I'll miss when I leave.
Posted : 23/11/2017 12:55 pm
Have you seen the [url= https://www.kitnetik.com/?p=1 ]Kitnetik[/url] hanger?
Hangs all your kit on a magnetic hanger which you can attach to a radiator, or hang up near a heat source..
Posted : 23/11/2017 12:57 pm
a £40 coat hanger?
Yep.
cyclists will fall for that no bother. hope the guy does well fleecing them.
Posted : 23/11/2017 1:05 pm
[url= http://www.argos.co.uk/product/8504405 ]Radiator Racks[/url]?
Posted : 23/11/2017 1:09 pm
Thanks to mudguards I stay clean above the knees.
Boots I hose off and leave by radiator. Trousers are pre washed in sink and then chucked in the machine.
Good mudguards make such a difference.
If it's just wet stuff I put an airier in the bath and hang it off that. Seems to dry overnight.
Posted : 23/11/2017 1:18 pm
