Does anyone know if 2015 Rockshox Revelation 29 forks can be reduced in travel from 140mm to 120mm.
Posted : 19/12/2015 3:49 pm
Did exactly this with earlier Revs rct3 29er , dual air. I simply dropped a 20mm spacer into the air shaft. A doddle. Works well. Not sure of year, I suspect 2014?
Posted : 19/12/2015 4:06 pm
I have 2015 revs, you need to change the air spring. I sent mine to loco, cost about £40 iirc
Posted : 19/12/2015 4:14 pm
I think they are 2015
Posted : 19/12/2015 4:17 pm
You would need fit a new 120mm Air Shaft. Rockshox Part R8022003.
This part will fit forks from 2013 onwards. Sram Tech have some good home service guidelines on Youtube.
Posted : 21/12/2015 9:22 pm
