dropper post protec...
[Closed] dropper post protection
I've just bought a bender fender and had an idea for a product. A butt fender thats longer at the seatpost end and extends down from the rails to protect a dropper seatpost from the elements.
If it could extend down far enough to reach the dropper post collar at full height then a small spacer could be zip tied to the collar to keep the guard away from the stanchion and it would just slide down behind the seat tube when lowered.
Let me know what you think would you buy it. I've put the idea to muckynutz who said they will look into it.
Posted : 22/01/2013 9:51 pm
Anyone
Posted : 06/02/2013 9:26 pm
I think there's mileage in it. Mainly because I spent a bit of time Sunday afternoon hacking an Ass Saver about trying to create something similar. I failed and Sneed up just strapping another section of inner tube over the post itself.
Posted : 06/02/2013 9:39 pm
Problem is about having the space when the post's dropped. I think my bikes would probably be fine but they both have long posts. But with a lot of folks' setups, it'd foul the frame.
Still, I do think there's a market. I wouldn't use one because my dropper posts are fit for purpose ๐Ÿ˜‰
Posted : 06/02/2013 9:58 pm
Please send 10 quid PP gift for one
Posted : 06/02/2013 10:00 pm
That's just ugly......... Lol
Posted : 06/02/2013 10:53 pm
Yep but it works and as it's stuck next to my arse it's hard to look at for very long. It also only cost 50p. Did I say it also works.
Posted : 06/02/2013 10:55 pm
Asked somthing similar a couple of weeks back - http://singletrackworld.com/forum/topic/so-what-you-keeping-the-wetdirtmud-etc-off-your-dropper-post-with
2/3'rds down the first page is my solution out of an old Neoguard. Actually works great. Dead easy to fit, remove, wash, refit.
Posted : 06/02/2013 11:06 pm
I was advised against (and could see the logic) the neoprene ones in close contact as you need to remove and wash them to avoid the build up of crap. I went with the idea above so that it was separated from the post completely. It gets a quick hose off and thats it - no need to remove.
Posted : 06/02/2013 11:11 pm
Get a gravity dropper.
Adil.
Posted : 06/02/2013 11:16 pm
adilc123 - Member
Adil.
No, I'd rather the infinite adjustment, a 30.9 post and something less clunky.
Post above is over 2 years old and fine.
Posted : 06/02/2013 11:18 pm
what about cutting a piece of innertube, removing the saddle, slipping it over the post and zip tying both ends ... the lower one just below the collar?
Posted : 06/02/2013 11:24 pm
As with wrapping in neoprene it traps the crap in there. Splash/splatter protection and the odd wipe down works well.
Posted : 06/02/2013 11:31 pm
Mike I beg to differ, the Neoguard doesn't trap the crap and the fact it takes seconds to remove and refit isn't an issue when cleaning the bike.
Each to their own though eh ? ๐Ÿ™‚
Posted : 06/02/2013 11:37 pm
Yep, I knew that I wouldn't get round to removing and cleaning so I went for the solution that was lazy and hosepipe compatible ๐Ÿ™‚
Posted : 06/02/2013 11:51 pm
Condom.
Ribbed one might be better if it has some structure. Cut teat off the end. Slide an o-ring up the seat post onto the stanchion. Slide the condom up teat end first to the top of the stanchion. Roll the O-ring down to secure the cut opening and use the O-ringy bit at the base around the bushing part of the seat post.
Nice and see through so you can see if any dirt gets inside and if you're lucky it might have the bonus of built in lube ๐Ÿ˜€
Posted : 07/02/2013 3:01 am
I cant believe they spend tons of cash to pay for the muppets to do this design.. Any mtb'ers knows mud (sand,grit) could get there and make the mechanism fail.
Posted : 07/02/2013 8:38 am
Who fits protection to their forks and shocks to keep mud off them? If not, why do dropper posts need them (gravity dropper excluded as it's fit and forget)?
Posted : 07/02/2013 12:11 pm
Personally I don't think they do- I've got a Gravity Dropper, which comes with one as it needs it, and a KS which doesn't because it doesn't. The infrequent servicing I give it never finds much dirt under the seal and after 2 years of unrelenting Scotland it's good as new. Wouldn't buy one I didn't think I could trust tbh.
Posted : 07/02/2013 12:36 pm
Ya just want an old sock & a couple rubber o rings !
Posted : 07/02/2013 12:40 pm
