Dropper Post Cable ...
[Closed] Dropper Post Cable Routing on Frames Without Guides
 P20
How are people routing dropper post remote cables on frames without guides? I presume it involves attaching it to the other cables hoses. Any pics would be good.
Posted : 17/06/2012 7:19 am
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=19014 ]These![/url]
Posted : 17/06/2012 7:28 am
Sharing the rear brake hose guides under the top tube, with cable ties replacing those clips (the ones that fall off all the time). Tidy.
chiefgrooveguru +1
Posted : 17/06/2012 7:33 am
With my gravity dropper I've gone for a single ring meaning i can use the front mech guides on the top tube.really pleased with how neat it looks. Gf just joins hers to the rear brake hose.looks ok!
Posted : 17/06/2012 7:58 am
I'm using stick on cable guides along the top tube with the GD on my Prophet as all the other cables & hoses run underneath the down tube.
They didn't stay stuck though, now cable tied in place!
Posted : 17/06/2012 9:02 am
 jedi
down the downtube for a reverb so the cable dont rub the tyre
Posted : 17/06/2012 9:03 am
chiefgrooveguru - Member
This.
slainte ๐Ÿ™‚ rob
Posted : 17/06/2012 9:50 am
Ziptie on the TT as the cables/hose are routed along the downtube. I was concerned it was ugly for about a minute and then got over it ๐Ÿ˜‰
Posted : 17/06/2012 10:06 am
 P20
Cheers guys.
Posted : 17/06/2012 11:10 am
I used the stick-on ones... None of them stayed stuck on though so I had to remove the adhesive tabs and reattach with strong glue. They're not coming off again i think! Not the prettiest solution but the cable goes exactly where I want it now.
Brake hose guides didn't work that well on my bike, they weren't in quite hte right place so I ended up with cable everywhere when I dropped the post. But ymmv o'course and it'd be a better solution, if it worked.
Posted : 17/06/2012 11:36 am
 P20
Another quick one, if you don't mind. Gear outer or brake outer?
Posted : 17/06/2012 9:37 pm
tucked between the cable for my front derailleur when i swap my GD between bikes.
Propably not the neatest solution but piss simple for swapping bettwen bikes
Posted : 17/06/2012 9:40 pm
Anyone know of any reuseable Velcro type solutions? Using a zip tie which works fine but I suspect I will swap to a standard post a bit for some of my Yorkshire Dales rides where I don't really need a dropper post.
Posted : 17/06/2012 9:45 pm
