Got to get a dropper post for a build I’m part way through. Looking for 31.6mm with around 150mm drop and internal routing. Are Brand X Ascend ok still? Pwd worth the money? Maybe OneUp v2?
I’m a bit scared of the Reverbs as I’d rather not have to bleed but happy to hear opinions.
Thanks
Tim
What frame is it going in
I think you have an idea :o)
2015/6 Enduro Expert (in medium)
Brand X is fine - good / reliable post. Not sure who the warranty is with though - I thought they were imported by hotlines which was part of Chiggle.
Oneup v2 is decent if you can find one - although they need a bit more tlc than the Brand X - I reckon the seals are a little smaller height wise to get a bigger drop in a smaller space. Simple to strip and regrease though with basic tools.
I’d defo avoid the reverb.
I think Trans X are ok - I believe they make the brand x branded post among many other rebranded Trans X posts - see Bird etc
That's why I asked Enduros are 30. 9 and the later ones 34 diameter posts
Bugger, would have sworn I put a 31.6mm in there……
Heads a touch fuzzy today so prob coming down with something :o(
Thanks for putting me right.
Tim
You won't go far wrong with this code SAVEJULYUK will get another £5 off
Aces. I’m going to do the slow walk of shame to the shed to check I’m going mad then will get that purchased. Thanks Tracey, you saved me a minor headache! Bottom brackets on order so fingers crossed I got that right.
Spec should be here to help with sizes
https://www.specializedconceptstore.co.uk/shop/n-a/n-a/2015-enduro-comp-650b-274/option/
Think it's a PF30 bb. If you need cranks to fit let me know
Nailed the BB! Ordered a Token one to fit Shimano cranks as I’m not a SRAM fanboy :0)
Seatpost in my defence didn’t have number on as it’s one of many old spares. I’m use to XC 27.2 posts so it felt a lot bigger. Will order the post now.
Thanks again.
Reverbs dont need bleeding to install them if you do it properly. I had one for 7 years and 1 for 5 years and niether ever needed bleeding. Both were removed and reinstalled a couple of times and didn't need bleeding.
