Drilling out presta...
[Closed] Drilling out presta rims
Hi got some lovely box section rims which are presta. Presta valves are evil things imo. Can I drill them out to schrader size?
Main concern is firstly their double wall but I think should drill fine.
Second concern - will this weaken the rim at all?
Anything else to consider?
Also out of interest why do mtb's use Presta's - Would I for example like presta's more if I knew that the rim was in fact stronger because of this design?
Many thanks
Posted : 11/02/2013 11:14 am
I also hate prestas and have drilled out rims in the past - I did not die.
Currently pondering whether it's wise to do this to some Stans rims as I have some very fetching dust caps sitting around I'd like to use.
Just renember to file any burrs off...
Posted : 11/02/2013 12:59 pm
I used to hate Presta, until I got a pump that actually screwed onto the valve, rather than just clamped on with friction. Don't bend the top of the valve now, which I always used to do.
Posted : 11/02/2013 1:01 pm
thank you
Posted : 11/02/2013 9:44 pm
Yes you can drill them without issue but presta are better.
Posted : 11/02/2013 9:56 pm
Rim will be stronger with a presta sized hole, presta valves take less effort to pump them up and they don't make your wheels look stupid.
Posted : 11/02/2013 9:58 pm
Drivel. Have you ever drilled a rim? Have you seen the tiny fractions of metal that come out? I've been doing it 20 years now, it doesn't make the slightest difference to rim strength. And I can mash a wheel with the best of them. ๐Ÿ™‚
Less effort? Not that I've ever noticed. Wimp! ๐Ÿ˜‰
Look stupid? Do they make your shock look stupid? Or you forks? Do me a favour. It's unnoticeable. ๐Ÿ™‚
Nobody has ever been able to give me a reason that stands up to scrutiny as to why Presta valves are any better at all. Not one.
OP - If you want to drill tour rims, fire away. You'll be fine. ๐Ÿ™‚
Posted : 11/02/2013 10:37 pm
Yep ๐Ÿ™‚
I have
Well clearly it will make a slight difference to strength as there is less metal there ๐Ÿ™‚
I have no shock and I don't need to put air in my forks.
It's unnoticeable
Maybe to you. Maybe you also ride ugly bikes? I'm guessing Orange 5 or Inbred ๐Ÿ˜‰
Posted : 11/02/2013 10:43 pm
Yep it's fine, you also wont have to turn down that emergency tube loan on the trail because you only use presta for absolutely no good reason.
๐Ÿ™„ What about the time wasted undoing the lock-nut?
Drill em ooot!!
Posted : 11/02/2013 10:58 pm
 jeff
Top tip - just push a presta dust cap into your schrader dust caps...
Posted : 11/02/2013 11:11 pm
Just check your rims first as my Mavic 317s had a little plastic grommet fitted which when removed allowed Schraders (the correct valve) to be fitted
Posted : 11/02/2013 11:35 pm
 Keef
[img][url= http://farm9.staticflickr.com/8193/8429583679_ce219b6ebf.jp g" target="_blank">http://farm9.staticflickr.com/8193/8429583679_ce219b6ebf.jp g"/> [/img][/url] [url= http://www.flickr.com/photos/92583610@N05/8429583679/ ]IMAG0272[/url] by [url= http://www.flickr.com/people/92583610@N05/ ]keef onespeed[/url], on Flickr[/img]
learn to love the drill....
Posted : 11/02/2013 11:51 pm
7.5 mm drill in case your wondering.
Posted : 12/02/2013 12:06 am
The amount of metal removed is minimal, it'll be weaker but only by fractions. Just drill it if you're really not that keen on presta.
Posted : 12/02/2013 12:24 am
