Drilled bolt-on fix...
[Closed] Drilled bolt-on fixied cog - anybody used it?
 Sven
Yes, if you mean the ones by http://www.velosolo.co.uk/
Does what it says on the tin, hasn't come loose yet, well made and not more expensive than 'normal' cogs.
Posted : 10/10/2009 8:55 am
looks like a very expensive way of going fixed
Posted : 10/10/2009 9:16 am
Works for me - a very inexpensive way of going fixed if you already have a 6-bolt disc hub 😉
Velosolo supposedly offer a lifetime replacement warranty too, just in case you ever wear it out.
Posted : 10/10/2009 9:18 am
Works for me too. I drilled one myself, a cheapo that came with an on one singlespeed kit.
Is a good way of going fixed because the chainline and spacing is easily shifted to suit different frames, and the XT hub is light and good quality.
I built mine onto an open pro rim, dishless with perfect chainline.
Mines for sale if anyones interested. (Whole bike)
Posted : 10/10/2009 9:24 am
 69er
[b]Goldtec![/b]
Posted : 10/10/2009 10:24 am
they seem really sensible to me - not sure why all fixed hubs aren't now made symmetrical & have a disc mount at either side (for 2 diff cogs, or cog & disc brake on the other side)
would stop WCA worrying (us all) about lockrings too
Posted : 10/10/2009 10:33 am
Actually, looking properly at hairy's link - what is that XT hub?
I assumed it was a standard (9sp) hub that had been reversed & the cog bolted on to the rotor mounts but it isn't, there's no freehub at the other end is there?
- is it a front hub with extra spacers, or what ?
Posted : 10/10/2009 10:57 am
It is a front with extra spacers and differnt axel, they sell a kit to do that too [url= http://www.velosolo.co.uk/shophub.html ]Here[/url]
Posted : 10/10/2009 11:07 am
But if you have an old road frame made of steel you can probably bend it to fit a regular front hub.
Posted : 10/10/2009 5:50 pm
