Double Chainring Co...
[Closed] Double Chainring Conversion (lowest gear)
I'm thinking of swapping my standard 9 speed triple set up for a 38/28 front with 11-36 rear.
I reckon my new lowest gear will be about the same as my existing 2nd lowest gear:
(22 tooth front x 26" wheel diam)/32 tooth (sprocket) = 17.85 gear inches
(28 tooth front x 26" wheel diam)/36 tooth (sprocket) = 20.22
(22 toothfront x 26" wheel diam)/28 tooth (sprocket) = 20.43
Am I right?
Posted : 30/01/2012 12:38 am
Seems right, did you use Sheldon's calculater?
[url= http://sheldonbrown.com/gears/ ]the man[/url]
I've just popped an 39/26 onto my existing 9 speed set up, only I couldn't afford to do the cassette at the same time so stuck with an 11-32. I was just going to use the MTFU approach ๐Ÿ˜‰
Posted : 30/01/2012 12:45 am
You may find problems getting a 9 speed cassette with 36 teeth.
Posted : 30/01/2012 12:51 am
Or go to chainreaction;
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=31059 ]heavy 12-36 shimano cassette[/url]
Posted : 30/01/2012 1:02 am
Not 11-36 is it though. You can fit an 11, but you get a jump at the bottom of the block.
IME a 12t gap works better too - id go 26/38 or 28/40.
Posted : 30/01/2012 8:25 am
I have a nearly new 38T chainring and bash going if you are interested. Found it too much for what I ride. email in profile.
Posted : 30/01/2012 1:29 pm
Cheers - acutally I was using the 'Ten-Bikes Jeff' calculation method and was just checking up on what he told me. ๐Ÿ˜‰
I am going 10-speed at the same time as doing the chainrings so no probs with the 11-36 cassette. I've got a new pair of TA 38/28 rings ready, but I see I'll have to swap the 28 for 26 inner to retain the lowest gear of my current 9 speed setup.
Thanks for the advice. ๐Ÿ™‚
Posted : 30/01/2012 8:15 pm
