Donot buy one of th...
[Closed] Donot buy one of these (micro pump content)
On a whim, which isn't another steel hardtail btw :P, I purchased one of these....
http://www.wiggle.co.uk/topeak-race-rocket-master-blaster-mini-pump/?utm_source=google&utm_medium=cpc&utm_campaign=uk&gclid=CJyykvK3i7QCFSHHtAodg2YAew
Don't, they are utter shite! The valve 'interface' is to 'fancy' and you loose air inflating/removing - thread engagement is not 'clean' and varies between each use even on the same valve. The rubber tube seems like a great idea to remove forces on valve but a) is too short, & b) is too short.
The ergonomics too are wrong, and the whole mechanism is beginning to feel worn/weak after approx. 10+ uses.
That's all.
LT
Posted : 08/12/2012 7:34 pm
Looks like a Lezyne copy to me,which I might add is a great pump,had one for about 18 mths now....Where as every top peak pump I've ever owned has stopped working & needed constant fettling with.....
Posted : 08/12/2012 7:40 pm
92% of owners who purchased one from Wiggle would say otherwise. 8% of their purchasers of the product are cack handed fops (probably).
Posted : 08/12/2012 7:43 pm
 aP
I've had one for a couple of years. I've used it 2 or 3 times, it's been absolutely brilliant, working perfectly and inflates tires quickly and easily. I think it's quite an elegant, simple and functional tool.
Maybe you're using it wrong?
Posted : 08/12/2012 8:14 pm
I have the MTB version and RD. Both are brilliant have worked with out fault for over a year now. Brilliant little pumps. Sorry!
Posted : 08/12/2012 8:42 pm
I have one and its great, no complaints.
Posted : 08/12/2012 9:27 pm
Should have [s]gone to specsavers[/s] bought a lezyne....
Posted : 08/12/2012 9:30 pm
