Does seatpost diame...
[Closed] Does seatpost diameter really make a difference?
To ride comfort?
Thinking of shimming a 27.2mm rather than using a 31.6mm
Posted : 13/06/2010 10:35 am
Interesting...
I've run 27.2mm and 31.6mm over the last few years. At my weight (10st), I don't think I can detect the slightest difference. There's movement in seat rails, tyres and so on going on, but I've never felt anything that I identify as seatpost flex. I'd guess that how the post is machined internally makes more difference than diameter alone too.
And shims are a PITA. ๐Ÿ™‚
Posted : 13/06/2010 10:40 am
I use shims rather than shelling out for different size posts. The USE ones are very good. Not sure how much difference a smaller post makes to comfort though.
Posted : 13/06/2010 10:43 am
increasing a tube's diameter by 10% increases stiffness by 30% if you keep the wall thickness the same.
For the same weight, a 10% larger tube will be around 20% stiffer.
My 27.2mm ti post flexes so much, I swear I have to point the saddle nose down to compensate.
Posted : 13/06/2010 10:55 am
Just go and ride the bloody thing instead of worrying about it.
Posted : 13/06/2010 11:01 am
 69er
Are you sure that's the seatpost 'flexing' just because it's Ti? ๐Ÿ˜‰
Posted : 13/06/2010 11:07 am
