Things like installing/removing a HTII BB, fitting a new cassette, that sort of stuff? I only ask as I just received a set of tools off the classifieds (HTII tool, cassette lockring tool and a chainwhip, oh and some cable cutters) and I can't believe how easy this stuff is! I can't believe it's taken me so long to get these simple tools and carry out this work myself instead of paying £5-£10 to my LBS every time I need to fit a new cassette or change disc rotors on a centrelock hub 🙄
A quick question though, do you really need to worry about torque settings? eg. on the cassette lock ring it says 40nm, just how tight is that? and is it hugely important?
I do as much of mine as I can. Cheaper to buy the tools and do it in most cases.
I believe the accepted value for torque is "just till it begins to strip the thread, then back it off a quarter turn"
do everything other than headsets, your right its quite easy, i just tighten stuff up till it feels good and tight but not like your going to snap anything if you push it any further. Nothings fallen off yet!
Yup. Been doing it since the early 90s.
Because
a) I don't trust bike shops
b) At first I couldn't afford it
c) Now I enjoy it
I'd rather spend £40 on tolls than £15 geting the jo done for me, and now I have every tool I need and sometimes get paid in beer.
Truing wheels has turned into building them, too....
Same as nbt, do what I can myself but don't build my own wheels or press headsets!
I tighten things till they feel tight, I also have a nice big hammer for bashing my cranks out though....
I do most of my own work although some stuff I leave to the pros - stripping forks/shocks mostly.
Things like fitting headsets/BB's, wheel truing I'll usually "borrow" my LBS workshop, I know the guy in there and in exchange for cake and coffee he's usually fairly accomodating.
Re your question on torque, having worked in many bike shops over the years I've kind of got a feel for most things but if it's vital then I'll use a torque wrench (again, LBS workshop time for that one!)
Do most stuff excluding fork service, wheel building and truing other than that everything else is fair game. I own a torque wrench so can torque to the recommendations but you can feel it it's to tight.
If you're using an expensive cassette (SRAM 990) then yes, it's important. Doing it up too tight can deform the alloy carrier. It's the only thing on a bike I always tourque up properly.
I think that the only thing I've not done is fit a headset.
surely that is bollox, a cassette just needs to be nipped up tight
You should learn. A basic service is VERY easy, replacing seals, changing oil and the like, and it makes a HUGE difference to the ride and the longevity of the fork. Same goes for aircan services on rear shocks. Need no tools other than an allen key to remove the shock (the can unscrews by hand) and again, makes a massive difference.
OK, you wreck your own expensive cassette then (or alloy freehub body come to think of it), then see how much bollox it is.
seeing as i have never buggered up a cassette or alloy freehub i will continue doing it up "nipped" up - why would it need to be stooooopid tight?
Same as PP, recently being doing more and more myself.
Because
a) I don't trust bike shops (split pinch bolts on frames, over torque'd, not changing both bearings, only changing the one cuz only the one squeaked (the other later collapsed completely), they also fitted cheaper quality parts but charged the same price as OEM parts
b) I couldn't afford it (rates have gone up so much recently)
c) I enjoy tinkering
now doing basic services on forks and shocks, we build (my girlfriend built her own alps wheels from birthday gifts and borrowing my park tools rig).
we have collected a pretty good set of tools and i've mad a few of mine own inc a loot to help bleed and clean hope brakes.
previously i've not had the time to do this stuff, now i make time. the girlfriend is learning too, she can now split her cassette off and fully service her freehub/wheel bearings, if it goes major i do the more techy stuff but it's not hard and it all helps keep things going
Some forks are easy (I've just changed the oil in my Pikes' lowers and wish I had plucked up the courage to do it before), some require a bit more finesse (I basically killed my old Vanillas trying to service them myself). Forks and brakes can be messy and requires a bit of planning to do properly, so I'd understand if anyone wanted to leave it to the shop.
Installing headsets is fun, lots of bashing with hammers, but I'd prefer to do it with the proper tools if it was a nice frame.
I used to get the LBS to fix punctures and yet have managed to progress to building up a complete bike (including pressing a headset) and recently necessity forced me into bleeding a hydraulic disc brake. I've even managed a fork oil change (although not replacing seals etc.). The only thing I've needed the LBS for recently was facing a disc mount (I don't have the tools).
I tend to get a bit stressy about things but do enjoy it and find it very rewarding. It's fun collecting the tools too.
The people on Singletrack are a great source of help as it the Park Tools website, a good book is handy too.
You don't need it stupid tight. But you're obviously perfect.
I use a torque wrench because I have one, which makes me perfect and a good mechanic.
I need to do a basic service on my E150 fork... been putting it off (mainly because I'm worried about not having a torque wrench, and also because it seems like a complicated piece of kit, though it is apparently a very easy service to do... I should just do it 🙄 )
also in the same "it's bollox" comment, my thomson post would squeak a bit no matter how heavy handed i got with it.
got a nice teng torque wrench this weekend and set about it with the wrench.
5.5 mn and bob's your fathers uncle! at first i was totally yer it's bs about torque ratings, so went at my occasional squeaky bars, 7nm on the bolts and it's all quiet, for my OCD that was worth the wrench alone (got it on ebay for £15 bargin!)
anyone recommend a decent torque wrench?
Do all of my own stuff including wheelbuilds mainly because i can and i enjoy it. If you are even slightly mechanically minded it is fairly simple with bikes as most stuff just bolts on. There is no substitute for the right tools though and when you have got them you can either lend them out or help your mates for beer tokens.
PeterPoddy - Memberseeing as i have never buggered up a cassette or alloy freehub i will continue doing it up "nipped" up - why would it need to be stooooopid tight?
so have i PP - only thing that i haven't attacked with my bbb torque wrench tho is the cassette
psychle - Memberanyone recommend a decent torque wrench?
http://www.bikegoo.co.uk/product.php/201/0
The only things I have never done to a bicycle are welding, respraying, facing/reaming, 'proper' damper service for air shock and replacing big seals and bushings on forks. Between my local riding mates we have pretty much all bike tools apart from reamers and cutting tools (which are welllllll expensive: you'd have to use them dozensd and dozens of times bedfor they paid for themselves) and it has collectively saved us quite a few bob in bike shop repairs.
It is often cheaper to buy a custom built wheel for merlin or crc than to buy the bits yourself, but I have built a few of my own and rebuilt a few for my friends.
I had a torque wrench but i lost it. 🙁
I do all my own bike mechanic-ing just so i know its right. All the stuff that people assume is complicated is actually very easy once you've found a step by step guide on the internet.
I'd say the toughtest thing is removing rear hope hub bearings. And building wheels because it requires a few hours and a bit of patience and you have to be in the right frmae of mind to do it.
i'd also say i've built tools like headset presses and nipple drivers (ohh er missus) and when others then borrow your tools (only good mates) it's nice that in a small way you have passed the idea on to others.
PeterPoddy - I've tried in the past on forks it wasn't successful they ended up at the tip 🙂 I will give it another go because I am sure it would be fine.
Like you I buy the tools as I go and it makes such a difference and saves having to worry about getting to and from the LBS and the qualiy of their work.
PeterPoddy - I've tried in the past on forks it wasn't successful they ended up at the tip I will give it another go because I am sure it would be fine
All the info is out there for the taking. RS forks are stupidly simple to strip down. I'll be starting on my Foxes soon, too......
I wish I had a shed 🙁 I live in a tiny shoe box flat in London, at least half of my available storage is taken up with bikes and bits though 😀
Anybody get shed envy?
Are those my tyres hanging on the wall? 😉
Same as PP. But I'm fairly used to it and dont bother with torque wrenches anymore as I rarely screw it up - I know 30lbft feels like "this much" force on a spanner that long. Though I've not recalibrated my arm in a while.
Cassette torque - just a good hand tight is plenty, no need to go all worlds strongest man on it, but make sure the lock ring is snuggly nipped up. Theres a certain sound to it that I'm struggling to describe, it goes from a soft whirring as the teeth begin to engage, then gets more definite vibration, then it gets a crisp vibration and I give it about 1/8 of a turn extra from that point. Might be easier to get a wrench on it lol.
Mr A! No, yours are just out of shot hanging in the rafters, top left!
I forgot to say that they were brilliant in the Alps. I used them for 2 days and I have to say that for going downhill I can't fault them. I changed them for something lighter for the PPDS as there's some climbing to do.
But thanks very much for lending them. Let me know when you want them back and I'll sort it out! 😀
It's not I don't trust bike shops, its just fun to fix up yourself. And a good excuse to acquire more tools. Like someone said everything just bolts together anyway, how hard is that.
Okay Pete, no rush. Let us know next time you're in Bristol and we'll go for a ride! 🙂
I'm a girl.
Yes everything bar facing and reaming and rear wheels. I've re rimmed front wheels and what's the problem with headset fitting?
Still got my old Campag bottom bracket and threaded headset tools (for when I finally get my old Gios back from the guy that bought it years ago)
c_g - thats no excuse. My other half fixes her own stuff, with a supervisory eye from myself. She's even done a driveshaft change on her car. Get out there with some tools!
<though I get the feeling I've fallen into a trap here somehow>
I do nearly all mine. Most of it is pretty easy bit I'm not too keen in wheel building, like someone above said you have to be in the frame of mind. I don't tackle brazing / welding.
I've never been too fussy about torque settings except with crank bolts, after having a crank work loose out on a long ride.
Ducati in the garage would be nice 😉
Do all my own work and as for tools not really an issue for me as iam a mech service engineer with £8000 worth of tools in two great big tool cheasts in my van so have turned my hand too nearly everything that needs doing, havn't tried wheel building yet!!but will soon 😉
Have re-rimmed wheels but not built from scratch (well, not without supervision from the LBS)
chvck - MemberSame as nbt, do what I can myself but don't build my own wheels or press headsets!
I've built a headset press to press headsets...
[url= http://www.sheldonbrown.com/ ]RIP Sheldon - the bike fettler guru[/url]
[url= http://www.parktool.com/repair/ ]Park tool advice[/url]
Most stuff including headsets and wheel building. But sometimes use the LBS for things like bearings as well if I can't be arsed with it.
Despite being the worst ham-fisted clum ever, I've gone from being distinctly edgy about repairing punctures (trail-side faffs were legendary) to doing most things now apart from wheels, forks and headsets. I am wheel-curious though. I'm grateful for a heck of a lot of patience and help from posters on here.
It's all because my "LBS" is an hour away (well the nearest one I'd trust anyway). Starting to really enjoy it now, but for some reason I cannot get to grips with Pro II hubs. There's some sort of curse on them as soon as I touch them. Follow all the instructions - I can almost repeat the Hope video word for word - but does it come apart? Does it go back properly? Does it heck! Determined to do one before my time's up, though.
