That's it basically. Mine needs a service but LBS was stumped as don't have the tool.
Oddly, they kept referring to it as a Pace BB which might just be because bike is pace and it was a busy day, but it's clearly got HOPE written on the side ๐
Willing to pay to borrow, or buy.
Ta, Rich
Will a good peg spanner not shift it ?
Not great on an old alloy cup but often works
Or find a few bolt of the right dia to fit the holes and place a lever between them , bit of a pita but Somtimes works
Is that the one with about 6 holes around the cup
Yes, 6 exactly.
I might still have one somewhere among the carnage of our recent house move.i never normally throw tools away so I will have a search for it tomorrow morning. If i can find it i will let you know.
You're a gent, thanks burt.
I'm 99% certain that we still have one in the workshop. I noticed you're in West Yorkshire, not a million miles from Ripon. I can have a look in the drawer in the morning and let you know?
Do you know what the pin size & centres are?
I've just had a look in the garage, I've got an old Brooks spanner I've had since I was a lad,but it looks like it could be imperial - 1/8" pins at 5/8" centres.
You can try it for nowt.
Edit: Wakefield. It's only got 2 pins though, so may make a mess of the holes if the cup's tight.
I have a six pin Royce BB tool. The pins are on an (approx) 29 mm diameter circle. I'm in South Wales, prefer you to collect tbh but can post if needed.
Monglu: Sent you an email cheers.
Brokensoul: Thanks, but the BB has been sat in a frame for 17 years and probably never removed, you're right, might make a mess of it, certainly increased chances if I try ๐ณ Thanks though.
Ambrose, I'll measure up and will be in touch if Mobglu can't find one; thank you. (It would need to be posted, obviously I'll cover costs upfront and a deposit if needed).
Should have installed an improved lighter stiffer external modern BB, that would have solved the 17year issue ๐
Email Hope?
They've a reputation for good customer service and I'd imagine a 17yr old bottom bracket might be something they'd be interested in helping with
It is the same tool as the Royce one, i've used mine on Hopes before. Ideally, you'll also want the spacers to bolt it to the axle to prevent it slipping,and the enormous socket and adaptor will help as well.
Email Hope?
Not a bad call actually if all other avenues fall through, got to ask them nicely for some 5 bolt custom rotors anyhow 8)
If its any help, I removed an 18yr old shimano sealed bottom bracket recently and other than a lot of penetrating oil down the seatpost and round the threads, the most useful piece of information I can give is find some way to bolt the tool onto the axle
I used an old pivot bearing and a washer to bolt the tool on using the pedal bolt
Then put the bike in a workbench and found the longest socket wrench I could find to shift it
It still took a while to get it out but as coatsey has said, bolt the tool to the bottom bracket
ok found it, i think. In my old befuddled brain,it had HOPE stamped on it but this one doesn't. it does have the 6 pins at 29mm centers.i think the royce and hope BB used the same tool and i've had both in bikes over time.
email me your address and i will post it today if i can get down there in time. (email in profile)
All sorted now thanks to Burt, cheers all for offers ๐
