Does a Maxxis DHF ...
[Closed] Does a Maxxis DHF 2.5 fit comfortably in a Pike?
Quick question:
Will a Maxxis Minion DHF 2.5in WT fit in a standard 2015 non-boost pike? Rims are 30mm internal Roval Traverse SL Fatties.
Thanks in advance.
Posted : 01/12/2017 10:15 pm
Yes.
Posted : 01/12/2017 10:34 pm
Yes. Can't take a photo as bike at lbs but have that tire in ibis 41mm rim in non-boost pike and plenty of room.
Posted : 01/12/2017 11:59 pm
I'm not sure how a non boost Pike compares to a non boost Yari - but that's what I've got and a 2.5wt DHF fits fine through it with room also for an enduro guard. It's on a 25mm internal diameter Dt Swiss e1900 wheel.
Posted : 02/12/2017 12:16 am
 qtip
No problem, it’s what I’m running.
Posted : 02/12/2017 1:00 am
Yes, been there done that
Though if you're on a 29er the DHF2.5 is overkill
Posted : 02/12/2017 1:18 am
Has anyone seen the 2.5 x 27.5 in a skinwall ? Only sourced the 2.3s
Posted : 02/12/2017 1:51 am
Cheers guys.
It’s a 27.5 rim so I think I will give it a go.
D
Posted : 02/12/2017 10:26 am
I have just popped a DHF 2.5 on the rear of my bike and it looks no bigger than the 2.35 Magic Mary on the front. I think it will fit fine.
Posted : 04/12/2017 9:52 am
