Does 0.1mm matter f...
[Closed] Does 0.1mm matter for seat post clamps?
My frame has a 30.7mm seat post clamp, looking to get a Salsa flip lock seat post clamp but the closet size is a 30.6mm, does the 0.1mm matter?
Posted : 26/02/2010 4:35 pm
i doubt it
i run a 27.2 seatpost in a 27.o frame and its fine
Posted : 26/02/2010 4:36 pm
 nuke
No
Inbreds, for example, need a 29.8mm seat calmp but 30.0mm does fine
Posted : 26/02/2010 4:43 pm
I agree with Kimbers but it may depend a little on the *exact* outer diameter of your seat tube. If you can get a vernier caliper it would be useful to crosscheck
OTOH a 27.0 seatpost in a 27.2 frame won't go (at least didn't in my case) it just drops down. A beercan shim works nicely in that case, but I don't think it will help in your case
worst case I suppose you'll scrape the paint of your frame at the clamp....
Posted : 26/02/2010 4:49 pm
Thanks, for the replies, just used my Aldi vernier and the measurements are 30.3mm to 31.1mm and it looks as if the paint is a little thicker in parts, so given your comments going to order the 30.6mm
Cheers guys
Posted : 26/02/2010 5:03 pm
