does it feel too small?
It is smaller than my bike looks on me, but that does not really answer the question.
๐
not really tbh.
If its a SC Blur then the top tube is quite short.
How tall are you/inside leg and what size frame have you got ?
Looks a bit short to me. But then I tend to ride stretched out a bit.
Looks OK seat tube wise to me.
looks about right to me.
you seem to be enjoying it by the look of that pic!!
Way too small. Sell it and buy another.
Isn't that the answer you were looking for?
the problem is that i've got short legs and a long body. it's a medium heckler and i'm 5"8 with a 30 inside leg. sometimes it feels like i'm looming a bit over the front and i do tend to go over the bars quite a lot. I've got a layback seatpost on it which makes it difficult to get my arse over the back end sometimes..
looks about right if you like them chuckable, which I do.
maybe i'm just a bit fussy but a longer top tube would be nice
i mean don't get me wrong i love my bike i built it and it rides ace but i have noticed the short TT and seing that pic surprised me a bit
Garden's in a shocking state. At least try to sweep up the leaves before taking photos.
why would a longer top tube be nice?
Bomberman,
Thanks for the tip-off: ๐
Now I know what I'll look like on the bike when I buy my SC later in the year (I'm the same height and leg as you).
I like a chuckable bike, so although that looks a bit short in the TT, it must be very nippy and easy to handle in mid air.
Nice!
my first instinct is "yes it does look small" - there is a lot of seat post showing and your arms are quite bent - but i dont know your bike well enough....
no problem belgian bob.
i'd like the TT to be a bit longer for 2 reasons mainly:
1) I prefer my arms to be straighter. not that i can't straighten them out but it links into the next issue which is
2) to avoid me being too cramped in the cockpit i'm using a layback seatpost. It gives me a really comfy climbing position but coming down the hills i'm finding it difficult to get my bum off the back of the saddle, unless i lower it. This has lead me to have the saddle at a height which is somewhere in between the perfect up-for-ups and down-for-down positions.
i can't see a way around this really unless they do a gravity-dropper in layback? and don't even try and suggest a longer stem!
drop the stem at the top of the hill? thats what I do.
its just your arse looks big ๐
I'm with neverfastenuff, you've got a M A S S I V E arse ๐ ๐ ๐
bomberman - Memberno problem belgian bob.
2) to avoid me being too cramped in the cockpit i'm using a layback seatpost. It gives me a really comfy climbing position but coming down the hills i'm finding it difficult to get my bum off the back of the saddle, unless i lower it. This has lead me to have the saddle at a height which is somewhere in between the perfect up-for-ups and down-for-down positions.i can't see a way around this really unless they do a gravity-dropper in layback? and don't even try and suggest a longer stem!
Err - if fit is so important, then surely the obvious answer is that you need a different frame? You just need to pick something which is longer for its height. Something like a Commencal maybe?
i have got quite a big arse. although i was in hospital this summer and dropped 3 stone to 7.5 stone and my arse completely vanished. i no longer HAD an arse! luckily i pulled through, and now the arse is back!
fit is everything. unfortunately i can't afford a new frame. maybe lower rise bars might help a bit...
i'm the same size as you and have the same bike in the same size. i can only descend with the seat down as like you i find the tt too short so end up over the bars a lot. it does feel too short but still is ace with the seat down..
Thought about a dropping seatpost (like a Gravity Dropper)? That way you can have 2 (or 3 saddle heights with little faff. I'm similarly short-legged and reckon this to have been one of my best-ever purchases.
fatmutha, what forks u running? i'm running 125's i should probably run a pike or similar 140mm fork to bring it up a bit...
but druid can you get one in layback?
bomberman - Memberbut druid can you get one in layback?
Why would you need layback if you're hanging off the back anyway?
Sorry guys - not trying to be smart-arsed here, it's just that I struggled with a frame for ages - stem length, height, angle, then bars, then layback seatpost. Took me ages to realise that I was [i]never[/i] gonna get it right without changing the frame.
because it just feels better with layback. why would anyone have a layback seatpost?
still didnt answer my question dammit im gonna have to use google now
Yep, too small - give it to me.
Sorry mate - no layback Gravity Droppers. Not in any of the other dropper-types either. I suspect the seals/mechanism would be a problem with the load being applied so far off-centre.
