Following on from my post on another thread about how my Hope X2s lack power
I sort of got thinking whether or not a 29" wheel needed a bigger rotor for the same stopping power over a 26" - everything else being equal
Did a google and found [url= http://www.physicsforums.com/showthread.php?t=212353 ]this[/url]
Which really doesn't come to a clear conclusion
Anyone got any 'real world' experience on this before I go away and buy a bigger rotor and adaptor?
26 vs 29 doesn't make any difference IME. I run 180s on my Soul (26) and Scandal 29er cos I am a bit fat.
I'm no physicist but I'd be surprised if a slightly heavier, larger radius wheel makes any perceptible difference when slowing 100kg of bike and rider.
probably. (Rob Warner can explain why better than me ๐ )
proportionally yes, 160's can look a bit silly with the clown wheels ๐
functionally not ime
Yes, the maths is very straightforward. For the same braking power for a given setup and force at the brake lever, you need proportionally bigger rotors.
29erkeith. You're wrong on the heating issue. Same amount of kinetic energy (OK, fractionally more because a 29er is slightly heavier) to get rid of = same amount of heating.
That's fine so long as you also agree that changing rotor size on any bike also makes no perceptible difference.
I should also add, I have the same brakes on two of my bikes - 29er with 203/180 and 26" with 183/160. Similar braking power. It was noticeable when I first built the 29er with the 183/160 combo that the power was slightly less than the 26" bike
I have 29" (or 700c) rotors on my road bike and they're nowhere near as powerful as the 160 rotors on my 29er ๐ฏ
๐ They're not rotors though. they're braking surfaces.
My 700c wheeled road bike only has rims that are ~25" diameter, what the hell is it you have?
& you missed this bit ..........
I experience no perceptible difference in braking power on the 29er with the same size brakes. Not that I have a 26er now.
Don't worry about it.
Running 183 and 160 Tech X2's on mine with no issues.
No,use 160mm discs on my 29er & always have done.Maybe if you got up to silly high speeds it might but otherwise nope,it's about the same...
For an extream example, BMX brakes are shocking, whereas 29'er v-brakes are pretty potent.
29er riders don't touch the brakes do they? I mean they're only meant for towpaths riding anyway
That would also mean that rim brakes would be better than discs in general - bigger braking surface so it would cool better,directly on the rim of the wheel instead of in the middle,so no loss of braking energy through all the spokes ...................Actually I may be on to something................Oh hold,they're ****in' useless when it gets muddy aint they......... ๐
Well yes, it was only whilst trying them in a moment of madness that I thought they may be a bit lacking
I've quarantined the bike for 48hrs just in case a wheel may explode as a result
piss poor example more like! seeing as BMX V brakes are also pretty potent.
I went out for an hour on mine last night on some pretty flat local trails, so no need to touch the brakes. Got home & once the bike was back in the house the wheels still exploded.
There is no explanation for this phenomenon, but it is one that I think we should all take more seriously.
Clubber has it but the 10 ish percent isn't noticeable IME.
Something along the lines of:_ To stop in the same distance at the same speed on a bike approximatelly the same weight will require the same amount of energy to be disipated" however "As a smaller area of rotor is being swept due to the smaller amount of rotation more friction will be required at the rotor"
so you probably just pull the brakes a bit harder, I can't see lack of power being an issue with any decent brake, and you should get better modulation too!
