Do you choose your ...
[Closed] Do you choose your steerer length thinking about resale?
Hey
Running my steerer longer than I would choose to with a couple of spacers (10-15 mm ish ) on top. I have no thought that im ever likely to sell the fork but the current bike has a very small headtube and stack height so if i cut it lower, it will become pretty much useless to anyone else. should i get my bike looking tidy and cut or leave it long 'just in case'
Posted : 24/06/2010 4:19 pm
I tend to leave 10-20mm margin for resale
Posted : 24/06/2010 4:20 pm
It's not something I give any thought to. I cut the steerer to where I need it.
I run my bars low, if I cut it for my own use it would be arround 150mm, which would make them worthless to everyone else.
Is startign to bug me though as a 200mm steerer pokes up far enough to stop the bike being stable when turned upside down.
Posted : 24/06/2010 4:22 pm
nickc - Member
Posted : 24/06/2010 4:25 pm
Same as bassspine plus different makes of frames headtube can vary a lot in size even if they are the same size frame, so if I swap frames there's no worry about new forks as well
Posted : 24/06/2010 4:26 pm
I do definitely, a few spacers is never a bad thing anyway.
Yes - I have left my steerer tube long on one fork as I am going to sell them when my new forks arrive ๐Ÿ™‚ My Talas' I have cut short as will keep those for quite some time ๐Ÿ™‚
Posted : 24/06/2010 4:27 pm
I have large bikes so all forks tend to have 200mm+ steerers but there has been many a fork for sale on here that I've had to ignore because the steerer is too short
It looks a bit w4nky having spacers above the stem but if it makes it more sellable then you just have to put up with it
Posted : 24/06/2010 4:35 pm
Same problem for me, my HT frame has a mahoosive headtube, which means i need a steeerer tube that needs to be 240mm long FFS! Thanks Marin, well thought out there!
Posted : 24/06/2010 5:15 pm
 jonb
not for resale but I do consider that I may need to swap them to another frame. Normally have about 10-20mm underneath and the converse on top.
Posted : 24/06/2010 5:50 pm
 mboy
I just cut em at 200mm, which usually means I need between 15-25mm of spacers on there too, but then that allows me to mess about with handlebar height too. Also, I run flat, or very low rise bars now rather than mid-high rise bars, which makes up the height difference.
I've found that much shorter than 200mm on the steerer and a fork is VERY hard to sell on in the future from past experiences.
Posted : 24/06/2010 5:53 pm
Mental...why even think about this? The bike is meant to be set up to fit you and your riding not so you can get a few extra quid when you have grown tired of it and want to sell it on...what a truly bizarre thought process.
Nope, the steerer is cut to fit me...if it doesn't fit the person who buys it then so be it...but while I'm owning it, I want it to fit me...
Posted : 24/06/2010 5:59 pm
Wait till you buy a bike with an integrated seatpost....
Resale? I buy them then ride them, not get fed up after 2 weeks...
Posted : 24/06/2010 6:12 pm
I don't buy my bikes to sell on.
I run all my bikes slammed and always cut the steerer appropriately.
Posted : 24/06/2010 6:18 pm
I bought my bike with riding it rather than selling it in mind so, no.
But if I went through bikes as quickly as some on here seem to then it seems like a good idea.
Posted : 24/06/2010 6:26 pm
[i]I run all my bikes slammed [/i]
translation please?
i swap forks between bikes, all have different headtube sizes so run steerer longer.
[i]Mental...why even think about this? The bike is meant to be set up to fit you and your riding, what a truly bizarre thought process.[/i]
it's still set up for you, it'll still steer the same and your bars will still be the same height, why not add some versatility?
Posted : 24/06/2010 6:32 pm
 nuke
I'm the same as thisisnotaspoon...I run my bars low. I have a set of 2008 Revs which are barely used but I know I'd get very little for them as the steerer is cut to 170mm...perfect for my Inbred but then Inbreds only have 105mm headtubes. On newer forks I've tended to leave the steerer at around 190mm.
Posted : 24/06/2010 6:33 pm
Nope, I actually commented about this earlier. My steerer is cut right down with only a 5mm spacer in case the next headset is a little higher.
I tend to use the 6o rise for height adjustment.
Posted : 24/06/2010 7:07 pm
Yes.
But mainly it's if I want to change frame in the future.
Posted : 24/06/2010 7:14 pm
Same as panda,
I'm sure I'll tinker around with bits some time and put the forks on another frame- so it's nice to know I'll have the option with a bit of extra tube
Posted : 24/06/2010 7:32 pm
Remember South Park and the island of misfit mascots?
It's right next to the island for forks with too short steerers.
Posted : 24/06/2010 7:52 pm
Low
Posted : 24/06/2010 8:00 pm
No, but I deliberately buy shirts two sizes too big, so when I get bored of them I can sell them on to some bloater without affecting the s/hand value.
Posted : 24/06/2010 8:02 pm
