Do you check your f...
[Closed] Do you check your fork and shock pressures?
I must admit I don't, not routinely anyway and wonder if I should. Once the sag and rebound is set and maybe tweaked after a couple of rides I tend to leave well alone. They don't seem to lose any pressure and I think I'd notice any increase in sag if they did. Should I have a word with myself or crack on?
Posted : 15/05/2020 10:14 pm
I do,  reasonably regularly, and especially before a proper ride.  Manufacturers tend to recommend checking before every ride. If you're not having any issues,  I'd say crack on!
Posted : 15/05/2020 11:05 pm
If it not losing air why bother. I don't once set up
Posted : 15/05/2020 11:09 pm
But every time you check you loose air. I'ver had multiple years of no air loss. It would be really obvious from travel if you lost air
Posted : 15/05/2020 11:12 pm
Cheers chaps. As I thought 👍
Posted : 15/05/2020 11:27 pm
 Yak
I do as I think the shock is losing pressure. Turns out it's me gaining some mass and the shock is fine.
Posted : 15/05/2020 11:30 pm
I check sag occasionally as my weight fluctuates. I also change air pressures when strapping camping kit etc. to the bouncy bikes. Also, shock service intervals are so short air pressures get checked several times a year during routine services. I've a notebook in the workshop where I keep a note of air pressures for different bikes. I like sweet running machinery.
I think most people incur expense from not looking after their kit.
Posted : 16/05/2020 12:28 am
If your sag is right it doesn’t matter. Check your sag periodically. Throughout the year the pressures will change with temperature so even if  it’s not leaking out, they’ll need a tweak a couple of times a year. Winter usually shows the pressures have dropped due to cold. If you are anything like me, your weight will also change throughout the year. Typically +\- 2kg. Often more drop during the first few months of Spring as I shed me winter cake fatness.
Posted : 16/05/2020 10:07 am
I check my sag now and again randomly, or if the suspension is feeling weird. Not sure what the pressure is, might have it written on my phone, but I know the sag percentages that work best on each bike and am pretty sensitive to them being off.
There’s not much air volume in a fork or shock so checking the air pressure inevitably means losing pressure and then correcting it.
Posted : 16/05/2020 10:18 am
Check sag every ride. Only if it's out would I check the pressure
Posted : 16/05/2020 10:49 am
I do a monthly check of all the bikes as I like things running well and enjoy spannering time as much as riding time. Shock and fork pressures get checked at that time or if I'm off for a long weekend/trip away. The only time I forgot to check pre-trial was on my last trip to Chatel and I had issues with a leaky seal on the shock letting the air out overnight. Most likely purely coincidence but I've been religious in checking the pressures every few days before a trip away now to spot any issues.
Posted : 16/05/2020 12:38 pm
and dont forget to check service intervals. I had no idea my new Sid RLs had a 50 hour service interval. At the moment that means servicing mine every 3 to 4 weeks!
Posted : 16/05/2020 1:30 pm
