see title.
No
No - vees / cantis require specific mounting studs on the frame and forks. If you're looking at modding a road frame for CX or gravel duties, most don't have sufficient clearance for bigger tyres+mud.
ahh, is there any reason for this? Does anybody know of any adapters/ a way around them not going on?
aah cheers dovebiker
Dave.
I've just put some mini v brakes on my old Kinesis CX bike, went on a treat.
The key point here being [b]CX[/b] not road bike.
Adapters so seem to exist if you don't mind it looking like a dogs dinner.
https://goo.gl/images/RyWYmy
You would need to consider too that if using drop bars, the levers would not be compatible with the brakes as cable pull is different. Again adapters are available but messy .
Mini vees work with road levers, but the problem with any kind of adaptor plate is that you've created another potential mud-trap. You might be able to get braze-ons put on a steel frame, but the cost would be comparable to buying a suitable used frame.
How old a road bike? You could always look out for touring bike forks (Dawes galaxy or similar...)
