Do Reverbs come wit...
[Closed] Do Reverbs come with bleed kits
Question in title?
Just ordered one from Wiggle. If not where's a good place to buy a bleed kit?
Thanks
Paul
Posted : 12/04/2013 12:54 pm
OE ones generally don't come with one, aftermarket ones do. Not sure which WIggle sell though. This is prob your best bet for a bleed kit.
http://www.epicbleedsolutions.com/products/bleed-kits/rockshox/reverb/complete-kit/
Posted : 12/04/2013 12:58 pm
Usually yes, but drop me a line if it doesn't. I have a spare I could flog you.
Some do, some don't - if you've got a suspiciously cheap deal, chances are you got an OEM one without the kit.
This is important though- remember they don't use DOT fluid, so don't use your already-used Avid kit!
Some do, some dont. Dont buy one, Ive had a Reverb for almost 3yrs and never needed to bleed it. Wait and see and then just borrow one if needed.
As with all bleeding, you only need to bleed the air out if it leaks.
Although the one mine came with gets used to do my brakes once a year.
Do you usually have to bleed if you have to trim the line down?
Posted : 12/04/2013 1:03 pm
Thanks guys, I'll wait and see if it comes with one then. Really wanted a Lev but the current deal on wiggle was too hard to ignore!
I think Wiggle usually sell aftermarket bits, I got one from there at Christmas on a similar deal to the one that just came up. It came complete with bleed kit and all the other bits and bobs.
Posted : 12/04/2013 1:06 pm
 Dino
No if you cut down as per scram tech on u tube then u should not need it
Posted : 12/04/2013 1:17 pm
Cheers Dino.
Posted : 12/04/2013 1:22 pm
