Do Raceblades fit a...
[Closed] Do Raceblades fit any road bike?
 Jase
Just got a set of crudracers for daughters bike but the rear doesn't fit, not enough clearance.
Looks like the raceblade longs require less clearance.
Has anyone fitted them to a bike with tight clearance?
I'm loaved to wasting any more money keep buying different models!!
Thanks
Posted : 22/12/2017 12:51 pm
No material other than a 1mm-ish metal mount goes under the brake so probably. They fitted fine on my secteur that has **** all clearance.
Posted : 22/12/2017 12:57 pm
I've got some normal size sks raceblades from a few years back. The back one fits ok ish but moves a lot and needs constant readjustment. The front one just outright is at the wrong angle for my forks so gave up trying to mount them.
Posted : 22/12/2017 1:16 pm
 Jase
Thanks both, have ordered a set.
Fully expecting them to not be as good as full mudguards.
Posted : 22/12/2017 4:37 pm
Raceblades are fine. Short ones don’t go under the brake so no clearance issue there. They can also be manipulated and bent all over the place to get them how you want them.
One small bodge I did though was to drill small holes in the guard just to the front and rear of where they attach to the legs. Then just looped a wee cable tie through and i’ve never had to touch them again (stops the rubbery horse shoe-y bit shuffling back/forward over time). Not sure if you’ll need to do the same with the current versions though
Posted : 22/12/2017 4:42 pm
Or you could use the screws the guards come with.
Posted : 22/12/2017 5:01 pm
Nah, that would imply you didn’t just bin them
Posted : 22/12/2017 5:55 pm
Posted : 22/12/2017 6:03 pm
 Jase
Cheers, will take care with the small parts in the box!
Posted : 22/12/2017 6:05 pm
I have raceblades on a Langster with 28mm GP4S. They are an older model and new ones look even sleeker. The front needed to be set near perfectly, and even then still I cannot pedal round tight corners (otherwise the front of my shoes hit the mudguards) and there is almost contact on the downtube.
After a few years I found the plastic clips got a bit loose so I Alraldite/expoy'd them together.
I have standard reach 105 brakes but my raceblades do not go under them- at the front they butt up to the back of the fork and on the back they stop just before the calipers.
Here is the best photo I have to hand:
[url= https://preview.ibb.co/mHwBAR/Langster_BB.jp g" target="_blank">https://preview.ibb.co/mHwBAR/Langster_BB.jp g"/> [/img][/url]
Posted : 23/12/2017 11:08 am
They fit my Giant TCR SLR with 5800 105 brakes and 25mm tyres. Had to chop down the rear a little at the seat tube as it was too close clearance where the seat tube curves with the tyre.
They obviously don't keep brakes and front mech clean because of the way they attach but they're as good as proper guards for keeping the rider clean - in fact they're longer and a have mud flaps which the proper guards on my other bike don't have.
Posted : 23/12/2017 11:14 am
@mtbtomo: I hadn't noticed the new ones have flaps- thanks. How "flappy" are they at the front and do the flaps protrude much?
@simonbarnes,legend: I epoxy'd mine, which I guess looks neater but means the guards probably can't be used on another bike. (That hasn't been a problem for me though as they'll likely to stay on the Langster till I bin them)
Posted : 23/12/2017 11:36 am
Your optimistic .
Hateful things
Posted : 23/12/2017 11:39 am
I've got a set of Pro XLs on a Canyon Endurace CF. Fit fine in the rear, but the front of a bit of a pair in the arse. Very close to the downtube, and the fork legs are toi chunky for the front breakers so they really don't sit very well at all. I took the front off after a few weeks. That and the constant readjustment after bashing it every rude with my toes whilst trackstanding or winding through tight spaces was really irritating. To the point that I took the front off on my way to work and rode home with it on my pack!
Posted : 23/12/2017 11:49 am
The mud flaps are stiff enough in themselves.
The front part in front of the fork does rattle/flap a little on high speed descents but compared to Crud mk3's they're solid.
Toe overlap could be a problem on any bike even it's designed to take proper mudguards - it's not a fault of the race blades themselves.
I have bike that takes proper guards and toe overlap is apparent but I accept that otherwise the frame would be somewhat long, and I don't need it any longer
Posted : 23/12/2017 12:32 pm
Mine also came with two different size attachments for the front, to accommodate chunkier fork blades/1.5" steerers.
Posted : 23/12/2017 12:33 pm
@mtbtomo- thanks, yeah agreed re. overlap and I should clarify I think there'd be overlap with *any* mudguard on my Langster
Posted : 23/12/2017 1:58 pm
 Jase
Update, they fit fine and were quite easy to fit.
Only downside is they wobble quite a bit but was expecting this.
Posted : 05/01/2018 2:43 pm
