Do I have to use Fo...
[Closed] Do I have to use Fork Juice or will any lube spray do?
I often see guys spraying their fork stantions before rides - I know you can buy Fork Juice for this, but will any spray lube (GT85?) do, or is there something magical about Fork Juice?
Cheers.
Posted : 31/07/2013 1:59 pm
Can't say I've ever bothered myself but IIRC Fork Juice is just a silicone spray, which you can get in all sorts of non bike places for less cash.
Posted : 31/07/2013 2:10 pm
As said, its a silicone spray. Maplin etc should do a cheaper, but less nice smelling (this is very important!), version!
Posted : 31/07/2013 2:12 pm
Any silicone based lube will do. I use my chain oil.
Fork Juice is just silicon spray- thicker than most though (it's a relabelled glazing product IIRC)
Fork oil does the job too, or chain lube... I'd stay away from anything really solventy like gt85, wd40 etc, never really know how it'll mix with seals etc.
Posted : 31/07/2013 2:23 pm
I put a few drops of chain lube on mine, then compress the forks a few times and wipe off the (then dirty) oil.
I use Fenwicks stuff, sure it's nothing magic but it does the trick. Can't be bothered chancing knackering loads of forks.
[url= http://www.fenwicks.info/bike/index.php/bike-lubes/suspension-lube-spray ]http://www.fenwicks.info/bike/index.php/bike-lubes/suspension-lube-spray[/url]
Used to use a different brand, can't quite recall what it was called. It came in a stupid little bottle that was totally impossible to squeeze onto stanchions. Truely was a wonder of modern design.
Posted : 31/07/2013 2:27 pm
Sceptical about this. The outer seals should have grease under them - spraying with thin lube would end up stripping this.
I reckon it's best used as a stop-gap to put servicing off for a bit longer.
Posted : 31/07/2013 2:31 pm
I lightly spray my forks with GT85 and then give them a light wipe off. Been doing this with my 1998 Boxxers and they are still working fine, so may not be too bad for them.
Posted : 31/07/2013 2:33 pm
Generic silicone spray works very well!
Posted : 31/07/2013 2:36 pm
 DrP
If you want nice smelling stuff, get the Juicy Lubes Frame Juice.....
Lurvely.....!
Also, the Fork Juice, though pricey, [b]does[/b] make the forks nicer, and it's satisfying to know you're clearing all the gunk from the seals with it too..
Plus, the spray means I can get it onto my rear shock shaft, which is a real pain if trying with oils... (meta 5)
DrP
Posted : 31/07/2013 2:46 pm
I use a fenwicks silicon spray lube and it works great, noticeable difference in the stiction departments and for keeping dirt and dust out from under your seals, thus prolonging the seal and stantion life.
However, I do mine AFTER a ride.
1st spray to soak into the dirt caught in the seal lip. Leave it 30 seconds and compress fork, it brings all the dirt back up with it on rebound.
2nd spray again after the clean to act as lube, leave over night/until you next ride. Stiction be gone!
Not sure it would provide much use before a ride, would be lots of liquid residue left for grime to stick too.
Posted : 31/07/2013 2:54 pm
IIRC fork juice ppl have been on before to say [i]it not just any old silicon lube..[/i], tbf it might be a better lube than normal silicon spray, but it's yet to convince me it worth double the price of the halford stuff. Admittedly a can of the stuff last so long, it might be worth buying it anyways.
[url= http://singletrackworld.com/forum/topic/is-fork-juice-any-better-than-wet-lube#post-814934 ]Link to the fork juice post I mentioned[/url]
Posted : 31/07/2013 3:00 pm
I have not noticed any difference on my forks, btw, or shocks.
Posted : 31/07/2013 3:28 pm
Always used GT85, never had a problem.
Posted : 31/07/2013 3:54 pm
If you have fork oil for servicing then just use that - tiz whats inside?
Posted : 31/07/2013 3:55 pm
Friend of mine used to work as a mechanic for Sram and said you should never put GT85 on your forks, shocks or reverbs. He said fork juice was about as good as you could get so considering a can lasts me several months I'm happy to use it.
Posted : 31/07/2013 3:58 pm
i've used fork juice and it is very very good. makes a noticeable difference.
i have friends who have bought "cheap" silicon spray from maplin etc and it seems to stay wet and attract loads of crap onto the stanchions. Fork juice doesn't do this.
mine lasted me a VERY VERY VERY long time. just make sure you cover your disc/pad before spraying it on....
Posted : 31/07/2013 4:06 pm
I've always used silicone spray. Motor factor/shops sell it cheap enough in big cans. As I understand it is kinder to seals than GT85 being pretty much inert. I think thats why it is used in food safe lubes. I would not use fork juice in this case, only because like cycle specific brake rotor cleaners, it's a bit over priced. Im sure it's a great product and does what it says on the tin but i'd feel i was getting ripped off. Us cyclists do seem to get ripped off sometimes, from fork oil to grease to everything else.
Posted : 31/07/2013 4:20 pm
 wl
+1 for Fenwicks. Great stuff, lasts ages, and reasonably cheap too.
Posted : 31/07/2013 4:22 pm
I just use a bit of Fox Float fluid (the heavy blue stuff) and wipe it away afterwards.
Posted : 31/07/2013 4:42 pm
I swear I read something by the fork juice guys saying that it is just a silicon spray but it has more silicon than most others (10%?, can't remember). I use it.
Posted : 31/07/2013 4:46 pm
I use this as its what I have on the shelf. Plus I use it on car door seals in the winter to try and prevent them from freezing.
[img] http://washford.scene7.com/is/image/Washford/776096?$prod$ [/img]
Edit: sorry, smaller pic
Posted : 31/07/2013 4:57 pm
Oh, and don't accidentally spray your saddle. That makes it quite difficult to stay sat on.
Posted : 31/07/2013 4:58 pm
