do hope rotors fit ...
[Closed] do hope rotors fit all calipers
can anyone tell me if hope floating rotors will fit my avid codes. are most rotors the same thickness
Posted : 26/03/2010 11:46 pm
Can't speak for Codes but Hope floatings don't fit all brakes, and some they fit but only just- my Oro K24s frinstance fit by a hair but lose any sort of adjustability.
TBH the floating rotors are a bit of hype IMO, I regret falling for it, they're not especially light and I never saw any performance advantage.
Posted : 27/03/2010 12:23 am
 devs
Performance advantage? It's a bit of metal, marketers have got a lot to answer for. As for fitting other calipers I have found that mono 6 rotors didn't fit my mono 4 calipers. I ended up grinding about .5mm off the rotor outer to get it to fit. I found that very strange and would probably never have noticed but it was ISO mount and there was no adjustment available save ovalising the holes, which I didn't fancy.
Posted : 27/03/2010 1:13 am
 DT78
I've used floating rotors with avid 3's if that helps?? (and shimano LX and magura louises) without any issues, though the 3's were a bit of a pita to setup right.
Personally I bought them as I like the colours - does that make me a bad person?!
Posted : 27/03/2010 1:16 am
Hope rotors have three brake track widths:
Mono Mini/X2/M4 are 13mm.
Mono/Moto M6 are 17mm.
Moto/Tech V2 are 20mm.
They're all roughly the same thickness at 1.85mm, apart from the completely-incompatible-with-anything-else vented V2 rotor, which is about 3mm.
The M6 rotor is the closest match to the Avid pad width.
Posted : 27/03/2010 2:00 am
