Do all disc brakes ...
[Closed] Do all disc brakes squeal in the wet/damp?
[#5060158]
or just AVIDS?
Posted : 12/04/2013 2:25 pm
think its pad rather than brake.... but i can get a super howl from my hopes and my maguras could sound like the old intercity 125 if you got the right conditions.
Posted : 12/04/2013 2:31 pm
My Avid Juicy 7s are silent, My Code 5s judder like hell but I think it's the rear brake mount tab flexing! Next frame will be rear post mount I think!
Posted : 12/04/2013 2:44 pm
It's been so long since we have seen rain I don't remember 😆
My Shimano will squeal a bit when wet, but not the howling I have heard from some brakes
Posted : 12/04/2013 3:32 pm
Agree about pads. Hope resin pads are quiet but squeal horribly in the wet. Hope sintered are noisier in the dry but less prone to squeal in rain. Personally I always go for sintered now - unless we get a really dry summer?!
Posted : 12/04/2013 3:41 pm
The squeal is caused by the high speed vibration of the pad on disc. So check the method of retention. You may find if its a spring type you can bend it to improve it. Or check your pistons retract properly, they may be dirty and sticking.
Posted : 12/04/2013 3:48 pm
My Hopes have never squeaked (besides when I got fluid on the pads and rotor..)
Posted : 12/04/2013 5:39 pm
 mrmo
i find sintered squeal, organic don't as a general rule. This is the same callipers, XTR 965, on a variety of discs, shimano, avid, alligator
Posted : 12/04/2013 7:19 pm
the same problem on car calipers is removed with a small amount of copper grease on the piston side.
Posted : 12/04/2013 7:21 pm
