DMR vault Superligh...
[Closed] DMR vault Superlight MG/Raceface Next SL
Got the above combo and noticed play in pedal bearings (I thought): changed bearings and, yes, shaft was scored/damaged at the bush end; changed em anyway (not sure how long that'll last); methinks somebody has mentioned this before and had a contact at DMR.
Also, when bearings were changed I noticed that all of the lateral play was sorted, however, pedal still wobbled; turns out the threaded sleeve in the crank is loose : any advice please ; do I still ride it??
Posted : 08/02/2015 12:41 pm
I had a set of DMR super lights sorted on warranty. Contact was Martin Gibbs at upgrade bikes. Martin@upgradebikes.co.uk
Posted : 08/02/2015 5:51 pm
Cheers for that
Posted : 08/02/2015 7:38 pm
