Dmr vault pedal ser...
[Closed] Dmr vault pedal service - bush!
[#4588580]
Morning all, anyone serviced a set of dmr vault pedals before? Just stripped them down which was easy, tool out end bearing and gave it a good clean and grease, but I can see absolutely no way of removing the drive side bush. It sits against a larger diameter internal shoulder in the pedal housing so it looks impossible to remove even with a tool as their is nothing to push against to pop out.
Service kits are available so it must be possible! Am I missing the bleedin'obvious?
Posted : 24/11/2012 10:24 am
Found it! Looks like I need to thread in a 1/2 inch bolt and yank the bush out.
Good video here :
http://mpora.com/videos/OyqyIljtx
Posted : 24/11/2012 10:31 am
