DMR component desig...
[Closed] DMR component design - EPIC FAIL!
OK, so I'm building a singlespeed: No problem, I've done it before, and I've got all the bits sat here ready. The icing on the cake is a good mate has very kindly given me a DMR Simple Tension Seeker, brand new it is. Result!
Now, correct me if I'm wrong here, but the whole point of an STS is to tension the chain on a [u]singlespeed[/u], yes?
So, esteemed STWers, please tell me why the effing groove in the effing roller isn't effing wide enough to accept a SRAM [u]singlespeed[/u] chain, which catches on every effing link and jams on the effing quicklink?
So, I've got to replace the brand new SS chain I've just cut to length. Arse.
TO DMR -
Posted : 22/04/2010 7:43 am
Which ss chain is it though, pc1 (or whatever its called these days)?
Posted : 22/04/2010 7:45 am
From the DMR website:
Designed to run with a geared chain, this limits the cost of going single speed on your existing geared mountain bike, remove your shifters and mechs, fit the STS and your ready to ride. If you wish to use a specific single speed chain - then please consider the Tension Seeker 2 as it will work with either chain type.
Posted : 22/04/2010 7:46 am
Apart from when you've already had the whole, brand new, drivetrain sitting in your spares box for a year or more, waiting for the right frame. Double arse.
Posted : 22/04/2010 7:50 am
Epic freebie part in fit for purpose shocker...
You must have an old 9 speed chain laying about..
ha ha FAIL
Posted : 22/04/2010 7:51 am
Would sir like a slice of
for breakfast this morning? 😆
Posted : 22/04/2010 7:52 am
I do. But that's not the point is it? **Stamps feet**
The 9sp is knackered, and I usually use 8sp chains on my SSs.....
One question -
If you didn't already know, why on earth would it even cross your mind a SS chain wouldn't work?
Posted : 22/04/2010 7:56 am
It wouldn't... I'd be as mystified as you are 🙂 . still funny though, when the full explanation as to why is posted for all to see on DMR's website 😉
Posted : 22/04/2010 7:59 am
Oh yeah, true enough. That's how they made it. But surely to god you'd have thought they'd make it wide enough for a SS chain, just in case, like?
Weather the info is there or not, it's still a big fat FAIL in my book. 👿
Posted : 22/04/2010 8:01 am
Doesnt it take an 8 speed chain either then?
Posted : 22/04/2010 8:04 am
It's your fail, they designed it to run on geared chains and the TS2 for SS.
Posted : 22/04/2010 8:05 am
It may also cross your mind that with a few minutes' careful work with a file you can widen the groove in the roller and make the free part you got work like the one you should have paid for...
: P
Posted : 22/04/2010 8:06 am
I was toying with widening it, but I don't want to wreck a perfectly good component for the sake of a £6 chain.
And, pray tell, why 'should I have paid for it' ????
Posted : 22/04/2010 8:08 am
No, it's not. How could I have known that? Why would I even think to question that a SS tensionner would not work with a SS chain? (The clue's in the name!) That's like finding bread won't fit in a toaster! 🙂
Posted : 22/04/2010 8:11 am
Clearly Peterpoddy's FAIL here - FAIL for posting about it before checking the component out.
Posted : 22/04/2010 8:14 am
Quite possibly that, yes, but I'd have only worded it slightly differently, that's all. 😛
Posted : 22/04/2010 8:16 am
What chain tensioner for digging yourself a really really deep hole in?
And a big up to DMR for designing separate chain tensioners for 3/32 and 1/8 chains
Posted : 22/04/2010 8:17 am
I agree with BigJohn - better to have a tensioner designed for the width of chain you'll be running than use a compromise?
Posted : 22/04/2010 8:19 am
If it had been advertised as "suitable for all types of chain" and you'd bought it and found it wasn't suitable for your type of chain, some sort of failure would have occurred on DMR's part.
If you've been given a component that you haven't properly researched and then found out that it's sold as being explicitly INcompatible with your chain and you then come on here whingeing about it somehow being DMR's fault, I think the thread title would be more appropriately [b]"PeterPoddy planning and reasoning - EPIC FAIL!"[/b]
: P
Posted : 22/04/2010 8:21 am
I might have a spare roller from a Gusset tensioner that I ran on my DMR ok. Email in profile if you want it
Posted : 22/04/2010 8:26 am
So let's imagine I'd checked the DMR site between finding out it won't work and posting this thread.... I would have written this instead -
[i][color=green]OK, so I'm building a singlespeed: No problem, I've done it before, and I've got all the bits sat here ready. The icing on the cake is a good mate has very kindly given me a DMR Simple Tension Seeker, brand new it is. Result!
Now, correct me if I'm wrong here, but the whole point of an STS is to tension the chain on a singlespeed, yes?
So, esteemed STWers, [b]please be warned[/b] the effing groove in the effing roller isn't effing wide enough to accept a SRAM singlespeed chain, which catches on every effing link and jams on the effing quicklink?
[b]Why? Because an STS is "Designed to run with a geared chain" according to DMR! Why on earth couldn't they make it a tad wider to work with SS chains too?
Now[/b] I've got to replace the brand new SS chain I've just cut to length. Arse.
[/i][/color]
It would have been something like that..... 🙂
but the STS is designed for use by people converting a geared bike to Single Speed 'on the cheap', not someone building a dedicated Single Speed bike?
Posted : 22/04/2010 8:31 am
With a bit of care and maybe a halflink nearly all vertical dropouts can be SS'd without an ugly tensioner (the only frame I could never quite get it to work on was a Pastey Howler).
But yeah, as much as I'm enjoying the winding up of PP as a spectator sport, you'd presume a SS tensioner to fit a SS chain without having to check the small print.
Posted : 22/04/2010 8:34 am
If you've been given a component that you haven't properly researched and then found out that it's sold as being explicitly INcompatible with your chain and you then come on here whingeing about it somehow being DMR's fault, !"
That argumnet simply doesn't stack up. Sorry.
Why should I even [u]think[/u] about researching it?
SS tensionner, SS chain. Makes sense.
You wouldn't even think about it, would you? And if you say you would, you're lying. I'll bet this is news to some if not most of the posters on this thread! 😀
Posted : 22/04/2010 8:38 am
S'fine. It's all in jest. 🙂
I was thinkin of a half link actually, but I'm unsure it would work, and I don't want to cock it up again...... Probbly just get a cheap 8sp on the way home I think. 🙂
Posted : 22/04/2010 8:48 am
But they make 2 (or more) different tensioners - Shirley one has to ask what the difference is?
Posted : 22/04/2010 8:50 am
I had the exact same problem, but it was easily solved with careful use of a power drill to widen the groove.
Posted : 22/04/2010 8:51 am
 Mike
Now I haven't checked this, but surely It's just the roller that's different on the two models?
Posted : 22/04/2010 9:03 am
 GW
did you write the manual on these too? 😛
Posted : 22/04/2010 9:12 am
This apparently unambiguous Poddy FAIL is shaking my world view to its foundations. I did not imagine that such things were possible. 😀
Posted : 22/04/2010 9:27 am
RTFM FAIL
Posted : 22/04/2010 11:27 am
That reminds me, the stupid headset question probably needs a bump...
Posted : 22/04/2010 11:31 am
Is this for real?
Posted : 27/04/2010 10:03 pm
