DIY seatpost shim
[Closed] DIY seatpost shim
 st
Anyone done a DIY seatpost shim from 30.9 to 31.6? Or any other sizes for that matter
With it being such a small difference I don't know of any proper shims available and wonder if a coke can shim would do the job. The seatpost woudn't be lowered at all and the frame swap won't happen until after Christmas so it's not something I can readily experiment with yet.
Ta.
Posted : 04/12/2012 6:02 am
[url= http://www.winstanleysbikes.co.uk/product/31366/USE_SS_309mm_Seatpost_Shims ]Ta-da...[/url]
Posted : 04/12/2012 6:48 am
Depends on whether a Coke can is 0.7 or not 😉
USE and others do them in that size I'm sure...
Posted : 04/12/2012 7:42 am
Coke can shims are great for the 90's or old hack bikes.
But if its a nice new frame, pay the £5.50 and get a proper shim. It'll be far worth it in the long run.
Posted : 04/12/2012 7:55 am
mate of mine did it out of a bit of brass sheeting... worked well enough.
Posted : 04/12/2012 8:09 am
Why not get a proper sized seatpost ?
Posted : 04/12/2012 8:22 am
If the coke can is the right thickness then it could be better than a proper shim - cans are made to a stupidly precise thickness, it's actually really good shim stock...
Posted : 04/12/2012 8:43 am
Anyone read "Zen and the art?"
It's a well known fact that you will probably die if your shims are not purchased from an official shim dealer and are not branded with a cool little logo. You have been warned!
Posted : 04/12/2012 9:10 am
Rode a bike with a stella can shim for ages - beautiful cannondale CAAD5 frame as well. Worked fine but I guess you need to be lucky with the thickness required.
It would be a bit of a ballache if you change your saddle height a lot
Posted : 04/12/2012 9:49 am
That's a good point - I'd rather quaff a Stella than waste money having to pour the Coke down the sink 😉
Posted : 04/12/2012 10:17 am
 st
Thanks all. Didn't expect to be able to get a proper shim so didn't even bother looking!
It would be to shim a Reverb out so saddle dropping isn't an issue (and yes I know the RS instruction is not to use a shim on a Reverb)
It seems like I'd end up paying a fair premium to sell my current Reverb and buy a new one of the right size when BFe frames eventually come back into stock at Cotic in the New Year.
Posted : 04/12/2012 10:50 am
bencooper - Member
Agreed - Coke cans are 0.1mm (.004")thick. I've used them several times to shim from 27.0 to 27.2mm. You can even roll a little lip at the top to hold them in place.
Posted : 04/12/2012 10:54 am
One for sale here 😆
[url= http://singletrackworld.com/forum/topic/clearout-includes-lupine-reverb-alfine ]http://singletrackworld.com/forum/topic/clearout-includes-lupine-reverb-alfine[/url]
Posted : 04/12/2012 11:06 am
