Rode Dragon's Back on Sunday and I'm heading over to ride the Beast tomorrow. On Sunday I noticed some diversions on the Beast around the Uncle Fester area, saying 'if you have ridden the diversion already then carry on to Uncle Fester.'
What's the crack? Is part of it closed?
If its the same as a couple of weeks ago then one part of mbr (which dragons back uses) is closed. It just means you do the bit before you cross the footbridge over the river/ravine for the second time twice instead of once (And miss the closed bit out)
Yes, it's False Teeth that's closed. The diversion takes you down Pugsley and Lurch, then you continue on the outward leg to Pink Heifer. When you come to Pugsley/Lurch/Fester on the return leg you cross back over the river - it's all pretty well signed (or was a couple of weeks ago anyway). If I was going to choose a couple of sections to repeat, they'd be fairly high up the list anyway ๐
Coolio cheers!
