Dismantling an asga...
[Closed] Dismantling an asgard shed?
Any tips on this? Looking at picking one up second hand and most adverts always say buyer to dismantle.
I've got a mid sized trailer so should be able to transport one.
Any ideas how long they take and what tools you need?
Yes I'm being tight but £500 is too much for a metal shed so looking used.
Posted : 20/08/2017 7:08 am
Reverse of building a shed I would imagine
[url= http://www.asgardsss.co.uk/metal-shed-instructions ]http://www.asgardsss.co.uk/metal-shed-instructions[/url]
Posted : 20/08/2017 7:16 am
It's just an awful lot of screws and reversing the assembly instructions will be easiest as suggested. An electric drill/driver will save you a lot of time
Edit: take a friend, very handy to have someone to hang on to panels as you undo them and help carry the bigger panels
Posted : 20/08/2017 7:31 am
 DT78
Did this on my own in December. About a 2 hour job. Make sure you have an electric screwdriver. The only thing I struggled with was removing the hydraulic lifts. I called Asgard who were very helpful. Basically you have to het a screwdriver under the silver clip and lever it off. Do this under a cloth or something as it is likely to ping off and you'll spend a while trying to find it. In my case this took quite a lot of persuading, clipping it back on the other end was a bugger too. Thinking about the wooden base was a little awkward to get out on my own but manage it with a crowbar.
Would be made a lot easier with another set of hands
I had a big a3 envelope for the parts, and wrote out the dismantling order on it as I went. Drawing around the appropriate screws so I knew which fasteners were for which step
Built up fine at the new house.
Edit - I didn't reverse the installation instructions, it's pretty obvious.
Posted : 20/08/2017 8:47 am
Thanks guys. Appreciate you taking the time to write detailed responses.
I'll take the Makita
Are the screw heads hex bit or actually screwdriver heads?
Posted : 20/08/2017 9:40 am
 DT78
Phillips. There are also bolts to hold the lid so a socket set or adjustable spanner. Don't forget a screwdriver or some type of prying device or you won't be able to decouple the struts from the frame.
Posted : 20/08/2017 9:53 am
it's pretty easy, I dismantled ours 3 times I think.
As they say, electric screwdriver and be careful popping out the shockers (or whatever they're called)
PS. Got a dismantled 4 bike in the garage in Manchester. Anyone want to buy it? Will deliver.
Posted : 20/08/2017 11:30 am
Yes. Pm me the sale fell through
Posted : 20/08/2017 1:09 pm
You'll need to rebuild it so the OP can dismantle it.
Posted : 20/08/2017 1:51 pm
Yep, its a doddle, i dismantled my 3 biker when i moved it from the rear yard to inside the garage. Took about 15 minutes to dismantle by myself with an electric screwdriver.
Posted : 20/08/2017 6:42 pm
