I know I can fit a IS disk to a centerlock hub buy using the DT gizmo.
Can I fit a Centerlock disk to and IS hub using something similar?
Posted : 12/11/2009 4:11 pm
Not that I am aware of as using an adaptor would move the disc too far away from the hub.
Posted : 12/11/2009 4:15 pm
boo 🙁 thanks.
Lot of faf it is then ...
Posted : 12/11/2009 4:36 pm
1) It's dis[b]c[/b]
2) You can get an adaptor that allows a 6-bolt rotor to fit onto a centrelock hub. You can't do it the other way round (centrelock rotor onto 6-bolt hub)
Posted : 12/11/2009 4:44 pm
i would go with rotor myself :p
Posted : 12/11/2009 5:22 pm
