Disc rubbing: can I...
[Closed] Disc rubbing: can I get a slotted +20mm brake adaptor?
 DeeW
I've sold a brake to someone on these forums: a shimano 160mm rear IS caliper used as a front (so should fit a 180mm disc) with a Hope +20mm IS to IS adaptor and a 203mm rotor. Problem is that the caliper just rubs on the oustide of the disc.
I seem to remember having a slotted adaptor in the past which would allow a small amount of adjustment, anyone know where I can get one from?
Any other solutions: a 200mm rotor??
Dave
Posted : 30/12/2009 10:33 pm
[url= http://www.bikeman.com/WIND-DISCADAPT.html ]there is this[/url], but then you might as well buy the right sized disk..!
Posted : 30/12/2009 10:56 pm
Is it a post mount cailper? I think all shimano ones, except for XTR, are. If so you can just put a washer or two in there to space the caliper out a little.
Posted : 30/12/2009 11:09 pm
A slotted adapter is only a few strokes with a file away.
Posted : 30/12/2009 11:10 pm
Used a 203mm rotor with a 200 mm caliper for ages using a 1.5mm washer between adapto and caliper. Worked just fine. On shimano brakes
Posted : 31/12/2009 11:06 am
the old black A2Z +20mm adaptors are slotted, they actualy have engraved on them 160 - 180/185mm adaptor
I have a couple (both in use I'm afraid) but they should still be around somewhere...
Posted : 31/12/2009 11:14 am
 devs
I had this problem when fitting M4 IS mount brakes to one of my frames. The Hope floating rotor rubbed ever so slightly and there was nowhere to fit shims. I cured it by holding an old oilstone on the outside of the rotor and rotating the wheel. Took a wee while but it runs fine now. Don't suppose this would work too well with saw or wavy rotors though!
Posted : 31/12/2009 11:16 am
one of these in fact...
close up shows the bit im talking about too ๐Ÿ™‚
http://cgi.ebay.co.uk/A2Z-Mountain-Bike-Disc-Brake-Adaptor-+-20mm-AD486-x-1_W0QQitemZ310158706236QQcmdZViewItem?rvr_id=&rvr_id=&cguid=bf0032461210a0e201a31f83fef1392c#ht_1670wt_1166 ]A2Z adaptor
Posted : 31/12/2009 11:17 am
 DeeW
Thanks everyone. It is an IS caliper mounted to an IS fork so can't use washers. Either the A2Z adaptor or a bit of filing to make a slot on the adaptor should be fine.
Dave
Posted : 31/12/2009 12:44 pm
