Disc braked Defy�...
[Closed] Disc braked Defy's - internal hoses and water drains ?
I have a 2016 Defy Advanced Pro 2, with internal routing. The back brake hose goes in through an open oversized hole at the top left of the downtube, which to me looks like a likely place for water ingress.
Have looked at a few others, and some online clips, like this one
and there is no seal on the hole. (I wondered if mine was missing something) Where does the water go, or more to the point, where does it come back out ?
Posted : 15/06/2016 10:02 am
I believe all internally routed frames have a big hole underneath the BB used when threading the cables to the chainstay?
Posted : 15/06/2016 10:11 am
Good question. My arkose has an open hole on the down tube (as it has internal routing for a front mech but doesn't come with one)
I've put a bit of tape over the top to cover it but I've always wondered about this
Posted : 15/06/2016 10:12 am
otsdr, ah, makes sense. Mine has a plastic cover/guide of sorts on bottom of frame there, so it probably incorporates a water drain, cheers
Posted : 15/06/2016 10:13 am
Posted : 15/06/2016 10:15 am
nice one, cheers. I am at work, so can't look at mine ๐Ÿ™‚
Posted : 15/06/2016 10:16 am
 jimw
There is a grommet on my Defy-it doesnt fit particulalrly well so may be yours has fallen off? Just going to use a bit of self amalgamating tape on mine now.
Posted : 15/06/2016 2:34 pm
jimw, thanks - nothing on mine, or the 2 others I looked at in the shop, or the one in that video clip I posted, so pretty sure it doesn't come with one, though I think it should !
Posted : 15/06/2016 2:51 pm
I have the disk equipped Defy and it does look a bad design, not in terms of water into the frame which will drain but into the cable outer.
Posted : 15/06/2016 3:28 pm
 jimw
Ianc since I picked mine up brand new from the shop yesterday, perhaps it was something they have added to later builds?
Posted : 15/06/2016 3:31 pm
Only thing is check is if the seat tube is open at the bottom. I've seen a few models that aren't.
Posted : 15/06/2016 3:44 pm
jimw - that sounds pretty likely, as it seem a bit of an omission, particularly when there are grommets on the other openings for the gear cabling
Posted : 15/06/2016 3:58 pm
