Disc brake mounting...
[Closed] Disc brake mounting help, first time build with a pic!
The frame below doesn't seem to have obvious disc brake mounting points and am want to use some shimano dual controls ( which i already have ) any ideas on how to sort this would be appreciated, thanks
[img][url= http://farm6.static.flickr.com/5145/5880345534_2bce0ec43d.jp g" target="_blank">http://farm6.static.flickr.com/5145/5880345534_2bce0ec43d.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/49207221@N06/5880345534/ ]bike frame 001[/url] by [url= http://www.flickr.com/people/49207221@N06/ ]our pics online[/url], on Flickr[/img]
Posted : 28/06/2011 8:28 am
no easy answer - there are some adaptors available that bolt on to the v brake mount and axle.
Posted : 28/06/2011 8:30 am
 grum
Get cynic-al to knock something up for you. ๐Ÿ˜ฏ
Posted : 28/06/2011 8:38 am
That frame is a perfect candidate for the the specialized disk adapter. It mounts to V post and a hole on the dropout. You'll need to drill the hole but its a large flat dropout so it won't be tricky. The hard bit will be finding one
Posted : 28/06/2011 8:44 am
didn't hope used to do a similar mount as well?
Posted : 28/06/2011 8:45 am
Most, if not all, of the other disk adapters mount to the axle and that makes it a faff to take the wheel out.
Posted : 28/06/2011 8:53 am
A2Z used to do one also.
Is the frame any good?? I considered getting a similar thing for an old V Braked frame I had. Decided against it as the frame isn't necessarily able to take the stress from the disc brakes, as it wasn't designed to.
Also I notice that the frame hasn't a replaceable mech hanger.
Posted : 28/06/2011 9:05 am
Is a replacement frame an option? Rather extreme, but still sensible..
Posted : 28/06/2011 9:06 am
thanks all, might have to re-think plans, the frame was a gift so no losses there. Might give single speed a go!
Posted : 28/06/2011 1:29 pm
