Disassembling a Shi...
[Closed] Disassembling a Shimano LH/Front Shifter?
Left hand/front derailleur shifter, XT Sl M770 for reference, was getting ridiculously stiff. So I've tried to free it up, previously with lube which did little. Then I figured it's probably gunked up so I try it with some degreaser. Which has duly done it's job but also done something else in the process as the ratchet's no longer locking/biting in the internal mechanism. I've tried to disassemble to see if I can fix it but can only get it about half way there. In the process I've looked for the traditional exploded diagram on Shimano tech docs. To help see how it's all held together but that's not proving to be particularly useful either as it only shows the external fittings not a full exploded view.
So with all of the above in mind can anyone please help me out with any of the following answers -
1. A full exploded diagram of the internals, which will show me how to take it fully appart.
2. A youtube link with a video showing how to do it.
3. The trick to getting it fully appart.
I've tried googling for the above but clearly my googlejitsu is poor as all I'm getting are links to the second rate tech docs like [url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/SL/EV-SL-M770-2708A_v1_m56577569830625645.pdf ]this![/url]
Posted : 08/04/2013 2:36 pm
Bumpety Bump for the day shift
Posted : 09/04/2013 9:18 am
There are no exploded diagrams of the internals as they are machine assembled and not designed to be taken apart
Posted : 09/04/2013 10:40 am
If you've degreased it then you need to give it a good dousing in lube and let that soak in. Try a bit of engine oil and try and operate the shift levers to work it in and out of the mechanism.
If you can get it working again, leave it to drain and then apply some grease to keep it lubricated.
FWIW they are not really able to be taken apart beyond removing some of the casing.
I've actually had an 8 spd one (M737??)in bits and managed to repair it by cannibalising another broken one for the bit.
Posted : 09/04/2013 10:58 am
Pretty much every single shifter I've tried to service has basically never been the same again. Either that or has produced its own exploded diagram..all over the garage floor!
Don't go there. Get another would be my advice.
Posted : 09/04/2013 11:31 am
Yes, lots of inbuilt ping****its in there!
Posted : 09/04/2013 2:48 pm
Further to the above managed to semi disassemble it with a great deal of finesse and some luck too. Turned out it was one of the springs on the ratchet pawls had come unstuck. So once it was returned to it's rightful position the shifter now works perfectly again and is reassembled and back in place.
Posted : 12/04/2013 1:22 pm
 sbob
frank4short - Member
No retreat!
No surrender! ๐Ÿ˜†
Well done for getting it working again. ๐Ÿ™‚
Posted : 12/04/2013 1:41 pm
