Hope Hoops Help
[Closed] Hope Hoops Help
[#5045168]
I might be swapping some wheels around and wondered whether I can convert a wheelset with a 20mm bolt through front and a 10mm bolt through 135mm rear to standard QR on both?
Thanks in advance.
Posted : 08/04/2013 3:31 pm
you need to know what hubs you have EVI, Pro 2 etc then you just buy the appropate conversion kit.
http://www.chainreactioncycles.com/SearchResults.aspx?Search=hope+conversion+kit
Posted : 08/04/2013 3:53 pm
Just standard Pro 2s.
I will have a look
Thanks
Posted : 08/04/2013 4:00 pm
Yes you can.
Front will be new end caps,
Rear will be a new axle and end caps.
If you are wanting to get rid of the 10mm through axle and end caps i would be interested in swapping them for standard QR bits. Email is in profile if you are interested.
Posted : 08/04/2013 4:09 pm
Probably will be but away at the moment but will contact you when I get back. Upgrading wheels on a Blood and swapping them on to another less burly bike.
Thanks
Eddie
Posted : 08/04/2013 7:18 pm
