Any good and how do they size up, is the 2", 2" wide
I've got the 2.0 XC ones on my Anthem X again now the weathers turned. Had them on in the Spring aswell.
They are very light and spin up quickly. Grip is excellent on pretty much all surfaces apart from on tarmac you can feel the tread moving around. The compound is pretty soft so the blocks can get damaged by sharp rocks/slate. The widely spaced block shed mud very well and they are narrow enough to cut through mud whilst being wide enough grip elsewhere.
If you just run them in poor conditions they are perfect.
The are slightly under 2" on my ZTR Olympic rims but the tread sticks out several mm beyond the carcass on the sides.
Thanks for that, may get some ordered
where's cheap?
I got mine from Germany - arrived within a couple of days and lots cheaper but the price seems to have gone up.
There's a seller on Ebay with them for £32.99 delivered
Thinking Dirty Dan or Baron which is the fastest rolling.
Totally different tyres I'd say
The Dirty Dan is a light 450g 2.0 XC mud tyre - spins up fast and sheds mud well.
The Baron is twice the weight but probably twice as tough and is bigger volume at 2.3
