Dinged rims and tub...
[Closed] Dinged rims and tubeless
 Joe
Has anyone thought of an ingenious way to fix rims with small dings in them, which will no longer seal a tubeless tyre on? Seems a shame to chuck the rim with such minor damage. Anyone tried filing/sanding down the area?
Got a fairly brand new Arch EX with a small ding maybe 3mm deep, and am cosntantly getting sprayed with latex through it.
Posted : 31/01/2016 4:52 pm
Heat and gentle persuasion? Tube?
Posted : 31/01/2016 6:32 pm
Shifting spanner over the offending area and gradually pull into line
Posted : 31/01/2016 6:34 pm
I used the end of the chain tool on my multi-tool, which happened to be just about the right width and bent it back into shape, worked a treat. Unscrewed the chain tool bit and used the bit labelled "2".
Posted : 31/01/2016 6:37 pm
yup, I just straighten mine with an adjustable wrench then tap any irregularities out with a hammer and block of wood. works fine.
Posted : 31/01/2016 7:06 pm
