Dim avid elixir 5 q...
[Closed] Dim avid elixir 5 question- reach adjustment
I have the elixir cr brakes on my other bike and has a very easy to use reach adjust dial. But the 5s reach adjuster is sort of tucked away/recessed behind in the main body. It doesn't look much different though. The dial seems on a spring like the cr, but for the life of me I can't get it to spin round. Tried jaming things in the holes in the dial to get some extra purchase, but still won't budge on either brake. What am i doing wrong?
Posted : 17/01/2011 11:25 pm
Mine move easy enough with a thin allen key in one of the holes and twist - but it's just plastic and feels like it could get chewed up if I got heavy handed.
Posted : 18/01/2011 7:43 am
so you just use an allen key and start spinning the dial round? Do you pull the dial out a bit, or does it just spin as you poke it with the allen key?
Posted : 18/01/2011 10:00 am
Just stick an allen key in and move it up or down (not left or right), depending on which way you want to go. Mine have always moved easily enough.
Posted : 18/01/2011 10:03 am
thanks. I was giving it some real umph and it wasnt budging. will try again tonight.
Posted : 18/01/2011 10:07 am
