Difference between ...
[Closed] Difference between Reba SL and Reba race (09)
I am going to buy some new forks and am not sure the difference between the RS Reba SL and RS Reba Race (apart from £25). I had a look at the descriptions on Merlin and they seem pretty similar.
Any reasons to spend the extra £25 for the Race forks?
Thanks
Posted : 30/01/2009 2:33 pm
A bit of weight I think (That's what it used to be), is all. It's a 100g or so IIRC, depends on how important that is to you I guess. Although, I'd not say the Reba's a particularly heafty forks any how.
Posted : 30/01/2009 2:37 pm
external or internal floodgate adjustment. weight is the same. all listed on the RS website )
Posted : 30/01/2009 2:42 pm
The only difference used to be external floodgate adjust in previous years. So it depends on how much hassle turning a knob with a wee allen key is compared to using a little dial, if the recent models are the same. The allen key is built into the rebound adjuster too, if you need it.
Posted : 30/01/2009 2:44 pm
I will just go for the SL, I normally set the floodgate and just leave it so no big deal there. Many thanks
Posted : 30/01/2009 2:47 pm
From the website it appears to be just External Floodgate (race) vs Internal Floodgate (SL), weight is the same I think...
Edit: beaten to it...
Posted : 30/01/2009 2:52 pm
