Dialled Bikes Alpin...
[Closed] Dialled Bikes Alpine riders, tell me.....
..... what seat clamp you are using. boring i know but i find my thomson 27.2mm post a little loose. the seat clamp i'm using needs to be done up real tight and it hurts my hand un/tightening it.
does any one else find the post a little loose? on the sanderson the (same) post fitted perfectly.
also, what forks you running, stem length and width of bars.
cheers
J
Posted : 22/03/2009 11:23 pm
bump?
was also thinking of using the current salsa clamp with a cut down hex key araldite'd in place. doesn't foul the frame.
someone tell me this will/won't work?
Posted : 26/03/2009 5:18 pm
Using a red one of these with my Thomson post:
Forks: Pike '08 454 Coil U-Turns
Stem = Thomson 70mm/0deg
Bars = Erm...dunno, RF Diablous O/S bars with about 10mm cut off each end.
Posted : 26/03/2009 5:23 pm
Salsa QR seeat collar (30mm dia), old Raceface XY post. Absolutley fine, no slippage.
I think the usual response to this sort of question is "use a coke can shim".
Edit: although Hope now do a 30mm QR seat clamp (new shape / design).
Posted : 26/03/2009 5:24 pm
cheap 30mm one from crc (brand x I think. never slipped with my thomson post
WIIIIIIIIDE bars on a 70mm/0 degree thomson stem
Marzocchi AM SL
Posted : 26/03/2009 5:27 pm
Salsa QR collar with Thompson seatpost
Titec Ringleader bars on a Titec Blockhead stem
Marzocchi Z1 Sport
Posted : 26/03/2009 5:30 pm
DMr QR one from CRC - About £7 and works great
Forks - 05 Marzocchi z1 freerides at 130mm
Bars - Sunline V2 at 710mm
Stem - Hope at 70mm with a 25 degree rise
Posted : 26/03/2009 5:42 pm
Salsa - snap. As in the same, its not broken.
Posted : 26/03/2009 6:17 pm
