Dialled Alpine what...
[Closed] Dialled Alpine what fork?
[#1400525]
The fork on my Alpine is pretty knackered so I am thinking of replacing it as its had a good run.
So looking around, and I am not sure to go for a Revelation U-turn, Lyrik (U-turn or solo air) or a Fox 36 RC2.
So anyone used any of these forks on an Alpine? or at all really and can comment on which one they chose any why
Posted : 10/03/2010 8:35 pm
I used a marzocchi 66 with 150mm of travel on mine in the Alps.
Over here I used a marzocchi Z1 with 130mm of travel.
I'd say 130mm is about right unless your only riding long, rough downhills.
Therefore I'd go for some rockshox pikes cos there cheapish?
Posted : 10/03/2010 8:51 pm
i just have a 140mm fork on my alpine and think it rides pretty good. for 99% of my riding it is fine except when i go for a weeks holidays to Europe where a 160mm fork would be nice but not essential
Posted : 10/03/2010 10:50 pm
got a 66sl on mine
set at 140mm for most stuff but is great at 170mm on steep long DH's
Posted : 10/03/2010 10:57 pm
i've a Lyrik (2-step) on mine. fork drops down to 115mm and is nice and stiff for climbing. run it fairly hard but sits at 140-ish w/sag when over the bars.
v. happy.
Posted : 10/03/2010 11:08 pm
I use a Z1 FR with 150mmm of travel. Thankfully they have ETA which makes climbing acceptable. I would like to get something with shorter travel for the UK but just can't afford it at the moment. Nevertheless, with the Z1s it can deal with most things that I want to ride but it is a bit too long in the wheelbase for very tight singletrack.
New Revelation Team 150mm Maxle, I reckon. Not as strong as a 36 or Lyrik obviously but still strong, and you get the Blackbox damping to boot, and only about 3/4 the weight (if you care about that). Very much loving mine. Depends on the intended usage obviously, if it's going to spend its entire life on DH trails or similiar I'd want something tougher probably.
Posted : 10/03/2010 11:25 pm
Float 36 RC2 on mine.
Posted : 10/03/2010 11:37 pm
2006 Marzocchi All Mountain SL.
Light and very plush.
Posted : 10/03/2010 11:45 pm
Lyrik u-turn coil on mine, very pleased with the combo and I know I would miss the lack of adjustability without it. It is so much easier on climbs at 115mm, general messing at 130mm, then wind them out for long descents.
Loads of tuning adjustments too.
Posted : 11/03/2010 8:45 am
+1 for coil lyrik, you can pick up 09 ones at very good prices if you look around too. try freeborn for a start.
Posted : 11/03/2010 8:51 am
Hmmm, might have a look at a lyrik then. I had Pikes which were good, but fancy a change. I am pretty heavy and rough on kit, so I want something tough.
Posted : 11/03/2010 10:18 am
 accu
have one of the first lyriks coil on my susser....after 3 years of abuse still works perfect..
its like a pike on steroids...
Posted : 11/03/2010 10:27 am
Sounds ideal then. I was wondering about a 36 Van or Float, but the stanchion issues with Fox put me off.
Anyone used a Lyrik Coil and Float RC2 and can compare the two?
Posted : 11/03/2010 10:29 am
Nope, but used a talas r before the lyrik and no contest. 07 mind.
Posted : 11/03/2010 10:41 am
Hmmm, I will keep digging, but the Lyrik looks to be a safe bet.
Posted : 11/03/2010 10:48 am
