Stiniog DH day fast approaching and need a couple of DH tubes.
£11 seems a lot of dough for an inner tube x 2 for one day's riding - are Maxxis worth it or do you guys find cheaper tubes just as good at keeping pinch punctures at bay?
I've been running Airwave ones with the green dustcaps for a while, I know the tubes help a bit but I've always found the pinch flat resistance comes from the tyre sidewalls so I've always ran lighter tubes and heavier tyres,
TBH disco I don't want to buy new tyres for one day so will use my High Rollers for the day and go for thicker tubes.
you're probably better off having 3 times as many normal tubes.
I'd agree withthe comments above re tyres being more important.
Apparently if you're running low pressures talc-ing your tubes is crucial as it helps prevent hotspots between the tube and the casing.
Apparently if you're running low pressures [s]talc-ing your tubes is crucial as it helps prevent hotspots between the tube and the casing[/s] putting a proper amount of air in will solve any issues.
FIFY
As above the better approach is DP tyres, I tended to find SP HR's to be flexi as hell and prone to pinching more than some other SP Maxxis.
After that have a couple in the bag if you want and change if you get a puncture.
I have done 100+ puncture free runs up to now at antur stiniog .
Tyres are high roller dual ply 3c compound with £ 3.50 tesco tubes.
The pressure in the tyres is fairly high compared with a more loamy course.
Invest in some good tyres and you will also notice the difference grip wise.
Enjoy your day.
I find it difficult to sort out in my head if you hit a sharp rock with a tube that is say 0.8mm thick as opposed to one that is 1.1mm thick that the thicker one would be able to take much more of a hit. i.e. little to nothing in it.
very nearly a 50% increase, that...
I use Specialized ones, they're not super-mega-thick but then they're also not too heavy or expensive 😉 Seem to work, at least it's a long time since i flatted (inc uplifts at antur and fw) Tyre is more important IME, a dh tube will still flat in a skinny tyre where a skinny tube in a dh tyre will usually get on better.
I think you are pissing in the wind if you think that a thicker tube is going to offer any more protection than a thinner one,
Hit your thumb with a hammer and then put a glove on and see if it hurts just as much second time round, I'm willing to bet it does,
High rollers will be fine, minions would be better, just run some correct pressure in the tyres, the HR front is a terrible tyre and gives little indication that it's gonna let go, that said tho it's an all weather course and offers stacks of grip.
I'm not sure what bike you have but I'm willing to bet 40 PSI will see you right,
Try CRC for tubes, X10 airwaves for £25 mines been in 3 months and been all over the place, the valve came off last week at Dalby replaced for a new one, that's not pinch flatted yet and it's been down worse than AS,
Well it does, but the super fat DH tubes do weigh a lot, when I used to use them you could tell when you hit the rim and it survived. Now I'm with the DH tyre normal tube camp.
i've been using the Intense FRO tubes for the last 8 years...not had a puncture yet...
http://www.winstanleysbikes.co.uk/product/11456/Intense_FRO_Innertubes_For_Racing_Only?gclid=CLb_4qawgbgCFVMQtAodBx0ADA
Have been using Conti Supersonics on the Voltage since last year. At least 100g lighter per wheel than normal tubes that's a difference I can feel
No punctures
DH tubes in normal tyres can do a lot to prevent punctures IME of riding in the Lakes and Alps with that kind of setup.
If that's all you can afford, do it. I've always bought the cheapest and the only punture I've ever had was riding over a screw in my back garden.
My 2 for £5 Asda ones survived 10 days in Alpe D'Huez 🙂
Maxxis DHF/R dual ply 2.5s
It's all about the tyres (DH tubes will help in some situations but they'll still pinch flat). If you don't want to invest in new tyres then you'll have to compromise on grip by upping your pressures. It's a trade-off... heavy but strong sidewalled (dual ply) tyres allow lower pressures which gives more grip, or lighter (single ply) tyres with higher pressures and less grip. If it's just for a day, pump 'em up.
that is possibly the worst analogy I've ever heard on here...
