Damaged chainring/t...
[Closed] Damaged chainring/tooth?
 PJay
[#9978651]
I've been noticing an odd knock/click in my drivechain when the driveside crank is parallel to the downtube. I can't find a stiff link in the chain and I've checked that the BB is running smoothly, so it's not a BB bearing. I've noticed that this only happens when I'm in the middle ring (yes I'm still riding a triple) so I'm assuming that it's a worn or bent tooth.
There's nothing obvious to my eye and, watching from the non-driveside, I can't see movement in the chain when the click occurs so is there anything else I should be considering before trying a new chainring?
Posted : 09/05/2018 12:42 pm
Sure it's not the BB?
Posted : 09/05/2018 1:05 pm
 PJay
Pretty sure, yes. I removed the chainset and spun the BB using the non-driveside crank without issue. As above it only seems to happen in the middle ring.
Posted : 09/05/2018 1:09 pm
