Cycling & healt...
[Closed] Cycling & health question
[#6201718]
Another question for the STW hive mind...
Had a few blood pressure checks over the past month. Being a fairly fit 40something, I've always had ok blood pressure - but BP was sky high when I went to the docs earlier this month.
Anyway, reducing coffee intake, a few other diet & "lifestyle" changes, and BP was right back down.
So, nurse does BP this am, and it's right back up - so she asks what I've been up to at the weekend.
Ignoring the opportunity for a risque reply - the only thing that I thought could have made a difference was a 4.5 hour training ride on Saturday.
SO - is training / riding going to have that sort of effect on BP? I always thought that activity / fitness was positive???
Posted : 19/05/2014 2:27 pm
Cant answer your question but what is the difference between a training ride and a normal ride?
Posted : 19/05/2014 2:55 pm
What did the nurse look like?
Unrelated....
I had to have my blood pressure redone at the end of my medical for Oz emigration as I'd just done Warrington to Whitworth then back to salford/mosside in rush hour as I'd forgotten my passport and was about to waste a chunk of cash if I wasn't on time to be seen late.
Posted : 19/05/2014 3:00 pm
The intention of the ride.
Posted : 19/05/2014 3:07 pm
You need a doctor on here, but I believe BP raises during exercise and will then eventually drop before returning to it's normal rate. Also, regular exercise is supposed to keep your blood pressure low.
After a tough long ride, heart rate, blood sugar levels and BP are often all over the place so not really the best time to get tested for any of those.
Posted : 19/05/2014 3:10 pm
Difference between a training ride and a normal ride? Whether or not there's any expectation to regularly regroup.
Posted : 19/05/2014 3:45 pm
Were the good readings taken at the doctors surgery or in the quiet of your home. White Coat Syndrome maybe? I regularly take my BP at home and 95% of the time it's fine. As soon as I step foot in the surgery it's through the roof!
Alcohol raises the BP so if you'd had a heavy weekend that could account for it 😉
Posted : 19/05/2014 3:59 pm
Relevance - high, I'd say. Petite, flirty mid thirties brunette 😉
About 3.5hrs...?
I normally either commute 1hr each way, or go for an hour blast from home.
Trying to shock the body into (semi)preparedness for June's Etape Eryri, so Saturday was a 4.5 hr fest of some of the Rhondda's steepest climbs, topped off by a slog over Rhigos Mountain...
Posted : 19/05/2014 8:08 pm
And what gender were they ?
Posted : 19/05/2014 8:09 pm
Your BP shouldn't be affected by exercise more than an hour or so earlier. Are you using the same arm each time? I'm inclined to think the nurse has a lot to answer for 😉
Posted : 19/05/2014 8:25 pm
