Cutting (splitting)...
[Closed] Cutting (splitting) a crown race .... Safe to do?
I'm swapping around the use of my Lefty fork (using a lefty for all kit) between bikes.
The current HS has an already split crown race which is needed for the adapter.
The new HS does not have a split crown race and one isn't available.
So I seemingly have one option ..... split the non split crown race. Is there any problem doing this?
Headset is a sealed jobbie but is fully integrated (no cups) if that makes a difference?
Posted : 03/01/2017 4:40 pm
I'd probably do it but use a bit of bearing fit to stop the race spinning on the crown if the bearings get a bit sticky.
Posted : 03/01/2017 4:43 pm
I've done it in the past, I lived.
Posted : 03/01/2017 4:44 pm
It's not actually a crown race so it'll be fine.
Posted : 03/01/2017 4:49 pm
Fine. As scotroutes is I think saying the bearings are in a sealed unit so the "crown race" is not in contact with the important bit of the bearing.
I run my singlespeed like this as it makes it easier to swap forks over when I put rigid forks on for the winter months. Never had a problem. Simply took a fine tooth hacksaw blade to it. Cut a slot and tidied up with a small file and a bit of abrasive paper.
Posted : 03/01/2017 5:05 pm
