cutting fork steere...
[Closed] cutting fork steerers.........help.
 ton
[#898561]
in the past i have always used a small hand grinder to cut fork steerers.
this usually leaves them on the pis5....
how can i get it nice and tidy....... ❓
Posted : 25/09/2009 7:12 pm
A pipe cutter usually does the trick.
Posted : 25/09/2009 7:16 pm
use an old stem as a guide
it doesn't really matter though unless it's very uneven
tape a spacer to it and use as a guide.
Posted : 25/09/2009 7:21 pm
what uplink said - but use 2 old stems if you have them, one top & one bottom
if you don't have stems you could tape headset spacers onto it instead
Posted : 25/09/2009 7:22 pm
Pipe cutter all the way - straightest cut you'll get.
Posted : 25/09/2009 7:25 pm
 dobo
spacers and hacksaw does the job and is probably cheapest, doesnt need to be 100% accurate anyway, i usually give mine a little bit of a filling down to to remove sharp edges and even it up if needed.
Posted : 25/09/2009 7:29 pm
oh, and leave it longish - on the off chance that you change frames in the future 😉
Posted : 25/09/2009 7:35 pm
As long as it's an ali steerer I'd use a cheap mitre saw to cut it, worked well enough for, don't think it shagged the blade. Pipe cutter is also a good way to go.
Posted : 25/09/2009 7:45 pm
Steerer guide and a hacksaw.
Posted : 25/09/2009 8:04 pm
Just get drunk and have at it with a chainsaw.
What's the worst that could happen?
Posted : 25/09/2009 8:09 pm
hacksaw and your eyes?
Posted : 25/09/2009 8:12 pm
Did yer get the brake mount fella?
Posted : 25/09/2009 8:13 pm
Learn how to use a hacksaw properly and you'll be able to cut almost metal nice and straight.
Goes like this:
1 - Measure.
2 - Check
3 - Measure
4 - Check
5 - Check & cut
6 - File rough edges & fit
Simplez
Posted : 25/09/2009 8:25 pm
 ton
nick
landed yesteray......cheers.
2 stems is the best idea so far..........thanks..
Nice one fella.. 🙂
Posted : 25/09/2009 8:35 pm
Tony, as said above a sturdy pipe cutter works a treat, perfectly square and the external edges are smooth.
Posted : 25/09/2009 8:52 pm
 ton
thats what ive used before tony just make sure your gentle and tighten it a bit at a time to try stop the edge from burring and remember to give it a quick file round the edge. last time i just used the underside of an old stem i bolted on upside down and a hacksaw
Posted : 25/09/2009 9:09 pm
Spot on, as mick said tighten a little bit, turn it round a couple of times, tighten, turn, tighten, turn etc...
Posted : 25/09/2009 9:15 pm
Two stems + hacksaw - quick, easy and effective.
Posted : 25/09/2009 9:16 pm
Those pipe cutters are half the price at Wickes, however the micro pipe cutter at Wickes is twice the price of B&Q.
Posted : 25/09/2009 9:20 pm
i've just cut mine with a pipe cutter and it worked a treat!
Posted : 26/09/2009 5:57 am
2 jubilee clips, width of hacksaw blade. hacksaw blade with lots of teeth on it
Posted : 26/09/2009 8:34 am
 nuke
For me the worry with hacksaws is the metal dust/shards that comes off and, unless all cleaned off really thoroughly, could cause damage if got lodged in the seals
Posted : 26/09/2009 8:44 am
Pipe cutters every time mate. NIce straight neat cut, no fuss.
Posted : 26/09/2009 9:08 am
