Cutting down carbon...
[Closed] Cutting down carbon bars
Anyone know why Raceface put a line on their bars, beyond which you're not supposed to cut? I've already gone beyond it on my used to be 800mm bars but I plan to take some more off and am presumably going to die horribly.
Posted : 10/05/2015 3:19 pm
 br
Presumable due to how they are made/configured.
But ignore it, can't be important... ๐Ÿ™„
Posted : 10/05/2015 4:27 pm
'cut down'? I thought the fashion these days was 'wider, even wider'.
Posted : 10/05/2015 4:29 pm
might be that the ends are a bit more flexible, and the central part is a bit stronger, or from that point the layup is different?
probably void the warranty if that bothers you.
Posted : 10/05/2015 4:34 pm
maybe thinner walls, not reinforced for fitting levers etc ?
Posted : 10/05/2015 4:37 pm
