Cutting Avid juicy ...
[Closed] Cutting Avid juicy cables?
So I've installed my new Avid juicy 5's but have a lot of excess cable
so what's the easiest way to cut them,and anything i should watch out for
Posted : 29/08/2009 11:46 am
Hose.
Make sure you have new olives to reseal them. I find cutting the hose with a stanley knife works a treat, without needing to rebleed the brake. Unbolt from lever, cut, fit new olive and insert, rebolt. Easy.
I think the Avid instructions document this pretty well.
Posted : 29/08/2009 12:09 pm
^^ Would that apply to hopes too? My front has a slight bit of a leak on the caliper end after fitting braided lines
Posted : 29/08/2009 1:16 pm
I blunted 3 stanley blades trying to cut my Avid Hose's it's tough stuff.
The big long razer sharpe kitchen knife went through them mighty well however.
Posted : 29/08/2009 1:38 pm
Tinsnips worked well for me, Nice clean cut
Posted : 29/08/2009 2:24 pm
Little hose cutter (like a cigar cutter).
Posted : 29/08/2009 3:17 pm
Anyone know where to get an avid juicy 3 olive & insert (google fail to locate a UK source)
Posted : 29/08/2009 7:08 pm
Have to ask, but the fact that they're marked as 05/06 is irrelevent then?
Posted : 30/08/2009 12:22 pm
Is irrelevant, all the brakes use the same ones. You can recycle them if you're really desperate, but you risk stripping the master-cyclinder threads by having to overtighten to get a used olive to seal.
Posted : 30/08/2009 12:57 pm
