Cutting a Carbon ba...
[Closed] Cutting a Carbon bar?
Safe to do outside with a facemask on?
Regarding the saw, is the fine toothed hacksaw I used for my Ally bars/fork ok;
Any other precautions I should take so as not to damage it?
Thanks
Posted : 20/12/2013 5:00 pm
yes, outside with a facemask. Use a new blade.
I'd check if there are any additional EU laws that might make cutting carbon tubes in the uk illegal, though ๐Ÿ˜‰
Posted : 20/12/2013 5:02 pm
I just don't understand this.What exactly is going to happen to you if you cut it indoors.There not cyanide based are they ?.A dust mask for gods sake.Do you work in IT or some other pussy foot job.Just cut the bloody thing.. ๐Ÿ˜€
Posted : 20/12/2013 5:06 pm
 kilo
When I've cut carbon steerers I've put a bit of super glue along the cut edge, supposedly stops any splintering
Posted : 20/12/2013 5:11 pm
robhughes, I read stuff about carbon dust but I don't know anything about that, doesn't hurt to check.
wwaswas, I've tweeted to LBC97.3 FM to check.
Kilo nice tip, thanks.
Posted : 20/12/2013 5:46 pm
I mark a ring then cut all the way around it to avoid splitting.
Posted : 20/12/2013 5:52 pm
I cut mine in the kitchen with a fine hacksaw blade and no mask, admittedly I swept up later, must be getting paranoid.
Infact 2 carbon steerers, one set of carbon bars and some thin carbon plate, not died yet ๐Ÿ™‚
Posted : 20/12/2013 5:53 pm
Carcinogenic, like asbestos. You really [b]don't[/b] want to inhale the dust.
Posted : 20/12/2013 6:00 pm
Not in the same league as azzy.Paranoia setting in. ๐Ÿ™‚
Posted : 20/12/2013 8:14 pm
Dremel.And HAZMAT gear (just be sure).
Posted : 20/12/2013 8:46 pm
Jubilee clip
Posted : 20/12/2013 8:47 pm
I'd do it outside just because the black dust gets everwhere.
I cut lots and lots of carbon fibre (talking 1-2" thick sections) routinely for testing. The main reason for this is to prevent mess and stop you getting in trouble with the OH for walking in carbon dust.
Mark a ring all the way round.
Clamp it carefully (i'd go for the wooden jaws on a workmate or something similarly gentle).
Put some newspaper down to stop you getting black marks on the patio that your cat will walk in (if you have one)
Use a sprinking/spray of water where you are cutting to capture the dust.
Use a fine saw with light pressure to prevent splitting (or if you have a diamond wheel tile cutter they are ideal)
Clean up with damp and soapy kitchen roll and dispose of in the newspaper. If you want to get the dust out of the middle give them a blast through with the hosepipe over the grass.
Now if you are attacking a big chunk of wing/wind turbine with an angle grinder then disposable suit, mask and goggles are a good idea!
Posted : 20/12/2013 9:20 pm
Posted : 20/12/2013 9:37 pm
Clamp it carefully in your stem
jubilleeeeee clip to mark where to cut and stop splintering
get his lordship to do it, got all the ppe
Posted : 20/12/2013 10:32 pm
I've got a black n decker work box. It'll be fine.
Might not cut it - see other thread.
Posted : 20/12/2013 10:33 pm
